Not the best pic, but it looks like your fresh water tank drain. There are typically 3 drains, hot and cold water low points (usually red and blue pipes) and the fresh water drain. Many people replace all three caps with valves so it is easier to drain the lines, which is done periodically, especially when winterizing the trailer. When you sanitize or winterize the water system , you'll be emptying water from all 3 locations. It's a good idea to keep a couple spare caps in case you crack or lose one when you are traveling.
NOBO 2023 20.3 Beast suspension, std. solar pkg
too many mods and repairs to list
Former - 2019 NOBO 19.7
2019 Ford Expedition Max, payload ~ 1700
