11-07-2019, 09:00 PM
Winterizing Tools
Going to Winterize my 2020 NoBo 19.5. Anyone have a tool list handy? Thanks
11-07-2019, 09:10 PM
I made an attachment that goes from garden hose threads to my quick disconnect on my air hose for a quick blow out. then simple pump in anti freeze
11-07-2019, 09:49 PM
Brake is on left
Other than a multi screw driver, pliers and a beer.... No tools needed
Seriously, thats all I needed. Screw driver to open the water heater panel for the bypass and pliers to remove the low point caps. The beer.... well, its beer.
http://www.forestriverforums.com/for...on-195618.html
11-07-2019, 09:53 PM
Serious question, what kind of beer?
11-07-2019, 09:59 PM
Guinness, it's the only beer to winterize by....
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-07-2019, 10:12 PM
Frosted Lager....Oil Can
2016 Coachmen Apex 250RLS Ultra Light 2023 Ram 2500 Big Horn Sport 3.73
11-07-2019, 10:18 PM
I forgot to mention the beer in fear of site member's getting involved and shutting down post
11-07-2019, 10:19 PM
Apple Pie Moon Shine. Two things get filled with Antifreeze at the same time....Me and the Trailer.
11-07-2019, 10:44 PM
Now that is good stuff
11-07-2019, 11:08 PM
You probably want a deep well 1 1/16 socket and wrench to drain your water heater. Sizes my very depending on brand of water heater.
If you're using antifreeze to winterize your lines, you may want to install a winterization kit like this - Camco 36543 Pump Converter Winterizing Kit (for RV and Trailer Winterization) https://www.amazon.com/dp/B01I4SMW28..._hMoXDb5QASYQV
If you plan to blow out the lines, I think there's a blow out plug you may want / need.
11-08-2019, 12:56 AM
Retired Old Fart
IF you water heater does not already have a bypass kit installed, you want that too.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
11-08-2019, 05:24 AM
Here's my list:
- Socket and wrench for water heater (you may find you need a cheater bar, too)
- Screw driver to remove panels to access water heater bypass and pump
- Hand pump kit
- Pump converter kit (permanently installed)
After draining the system using the low water drains, I use the hand pump to send antifreeze through the black tank flush, fresh water and city water connections on the outside. I can watch for the antifreeze to come out of the HW tank.
I then go inside, bypass the heater, and use the pump converter kit to send antifreeze through the rest of the system.
That's basically it. Then any socket or wrench you'd need to remove the batteries if necessary.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
11-08-2019, 07:12 AM
Brake is on left
Either Dales Pale Ale or Sierra Nevada. Only two i like from a can. Prefer bottles but they do not recycle glass here and I hate putting glass in the trash.
11-09-2019, 11:12 PM
Thanks for all the help! It was ridiculously easy to do.
