Originally Posted by BehindBars
There are dimmable puck lights available, as well as choices in color temperature. Or, you can add an LED compatible DC lighting dimmer for your existing lights. The choices are almost too numerous to list. May you can narrow down for us just what type/style you would prefer to have.
X2
I see it is the OP's 1st post, welcome!
As mentioned, this has been discussed many, many times and there are lots of options depending on what YOU want to do.
You can get dimmer/different color pucks, you can colorize the lens, you can black-out some of the LEDs, you can add dimmers... etc.
I suggest you spend a little time perusing the forum for other posts about this topic. If you are unsure how to search, ask and you will get pointed in the right direction.
Days Camped ☼ '19=110 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=93
