12-05-2022, 10:34 PM
Does this look a little off?
This middle slide that has the fridge, oven and tv/ fireplace looks crooked to me!
When inside though, seems ok!! Put a level on the kitchen island right across from it.
Then turned around and put level on slide counter.....see the difference?
Is there a way to adjust the slide...bring the front up or back down? Don't notice any this off in the whole park.....
This is the 2022 Ahara 378 BH-OK. Just got it...brand new.
12-05-2022, 10:37 PM
No Pic!
12-05-2022, 11:36 PM
It’s hard to use counters for level. No telling if they were installed level..lol…
I think it’s an optical illusion You see the slide top edge against the RV roof line. The roof line slants down about halfway down the slide length. It seems to be aligned with the rear slide and the decals look like they line up for the two slides…
12-05-2022, 11:50 PM
^^^ x2.
Looks like an optical illusion to me too. If you take a ruler and run it along the slides in the top picture, the line is straight across the top and bottom. It's the roof line that creates the illusion because of the way it slopes up.
On our REV, we have a friend that swears we're never level because the fender trim over the tires creates the optical illusion that it's not level. Had to get out the level to prove it and they're still not convinced.
2015 Dynamax REV 24TB class C
12-06-2022, 01:00 AM
whole trailer looks a bit uneven ...........front appears low?
could be the camera angle or the road crowning
certainly have to ignore the roof-line that looks way suspect!
my2c on slides.... any small error on level make it so the slide wall is the lower...
any water that gets in........... will drain out rather than in...
and for those that have slides both sides....
you're on your own there!
if you're asking whether the slides are fitted correctly
when you look at the black painted area .... looks good to me
Tarpon Springs FL
2022 Salem 24RLXL
12-06-2022, 07:55 AM
As already mentioned, using a straight edge on the photo, the middle slide looks aligned to the rear one. The sloped roof just makes it look a little off. As for the level measurements, be happy with what you have and don’t expect much. Remember, this is an RV, slapped together quickly and carelessly. I can put a level in various places in my motorhome and get lots of different readings. I’d drive myself crazy if I expected perfection.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
12-06-2022, 02:42 PM
Okay, that's what I did
Originally Posted by Reverse_snowbird
^^^ x2.
Okay, here's what I did. - Downloaded the photo.
- Zoomed it for better resolution.
- Marked two points at the bottom of the frame, one by bush in front of the axles, the other at the rear, just behind the small slide.
- Told the photo editor to rotate the photo until the line defined by those two points was level (parallel to photo frame).
- Drew a level (parallel to photo frame) red line just above the slide.
My conclusions: - The slide is properly oriented with respect to the trailer.
- One optical illusion is caused by the trailer roofline.
- The other optical illusion is caused because the photographer did not hold the camera level.
Larry
12-06-2022, 02:58 PM
It is an illusion. The roof has a camber to it.
2018 Coachmen Freedom Express Liberty Edition 231RBDSLE
12-06-2022, 03:35 PM
Ok, thanks for the perspective! Appreciate that, maybe I can calm down a little bit!!!
12-06-2022, 04:21 PM
Kanadian Kamper
You’re good!!!!
If the drink stays in the glass…….you’re level.
Ken and Terry
Former Georgetown 330TS owner for 10 years with more mods than I can count
12-06-2022, 06:23 PM
Heck if I get set up that close I'm good. Measure once and forget it.
12-06-2022, 09:00 PM
Now, about that counter top….
2022 Cherokee Wolf Pup 18TO
2022 Dodge Ram 2500 6.4l Bighorn
12-06-2022, 11:08 PM
[/LIST]
So you replicated the ruler measurement and reached the same conclusion!
I applaud your diligence.
12-15-2022, 11:56 PM
Two shots of whiskey will straighten that right up
12-16-2022, 12:35 AM
I would measure the distance between the rear slide and the slide in question. Measure the top distance and bottom distance. I'm sure you will find that they are the same measurements.
12-16-2022, 12:43 AM
Novice Travel Trailer Guy
It’s crooked dude.
2018 Flagstaff Micro Lite 25BRDS Travel Trailer
2018 Chevrolet Silverado 2500 LTZ
