Old 04-11-2020, 01:08 PM   #1
How do I stay cool during the summer
Hey everyone I am new to full time travel trailer it is a East to west silver lake. What things can I do to help keep inside cool during the summer and not over work my a/c? Thanks!!! Safe travels
CaptP is offline   Reply With Quote
Old 04-11-2020, 01:21 PM   #2
frank4711's Avatar
we make every effort to book shady spots ....
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
frank4711 is offline   Reply With Quote
Old 04-11-2020, 01:24 PM   #3
Some ideas:
Park in the shade
If no shade make some using sun screen material suspended from overhead clothesline like supports.
Add awnings to windows.
Most RV's get hot from direct sun more so than stick and brick houses due to lesser insulation.
If you are in an RV park with water hookup, and in a low humidity area, a "Patio Mister" set up on the roof will create some cooling over the roof area. Mist should be fine enough it all evaporates and little or none flows off roof from gutters.
A sun screen from your main awning to the ground helps a lot too if that side is facing mid to late day sun.
That said, i prefer to camp in the woods during hot summer months. Rarely need AC.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 04-11-2020, 01:32 PM   #4
Once you get camping, you'll soon figure out where your greatest heat gain is. You may have a large window that just absorbs the sun. In that case, go to your local hardware store and get some reflective shade https://www.campingworld.com/reflect...E&gclsrc=aw.ds
or pulldown blackout shade.
They also make 'pillow' type blocks for vents.
Cool down the trailer in the early morning before the sun gets too hot.
Buy a fan to circulate the air within the trailer. That will make it 'feel' cooler.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 04-11-2020, 01:40 PM   #5
U.S.ArmyVeteran's Avatar
In our old trailer. We tinted the windows in the bunk house. Since the view was not important when you sleep. You could tint more windows.
Also got a shade to hang off the awning. These are also nice for privacy.
I discovered that the "sky lites" are really a big source of heat in direct sun light. I never did figure out a good answer for that. Our new trailer does not have one.
Good luck
U.S.ArmyVeteran is offline   Reply With Quote
Old 04-11-2020, 02:07 PM   #6
Good luck
https://www.amazon.com/Camco-Insulat.../dp/B0024E6QX0
2011 Traverse LT, 3.6L, FWD
Old 04-11-2020, 04:31 PM   #7
Thanks everyone
Old 04-12-2020, 12:50 AM   #8
dbledan's Avatar
A few more additions.
Shade is the best. Here are a few morenfrom the humid midwest.
Make sure you don't close the dump vents for the AC when hot outside or during initial cooling. My compressor freezes up if I do that and it will slowly stop cooling until the ice clears.
Remove the filter maybe the cover and look up into the AC unit. Make sure there is a divider that touches between the vent and the return. Add tape to actually seal off a clear area from the return.Your AC will cycle too much if the air just recirculates right back into the AC without going out into the trailer.
Make sure your roof vents have good flow. If low or no flow look for threads on how to open them up or check them with a boroscope.
Let your ac cool the unit down a bit (about 10 degrees from abient) at a time and then let the compressor chill a bit with the fan on. I do this by just turning down the air in 10 degree increments amd waiting to hear it stop...then turn the fan on for 5min and set it another 10 degrees lower. This will prevent icing of the compressor.
Happy camping!
dbledan is offline   Reply With Quote
Old 04-12-2020, 09:17 AM   #9
Herk pimped his AC:
https://www.forestriverforums.com/fo...-ac-42280.html
Old 04-12-2020, 10:28 AM   #10
In the West, we gain elevation.
Low elevation deserts in the winter.
High elevation mountains in the summer.
ppine is offline   Reply With Quote
Old 04-12-2020, 12:01 PM   #11
In the East, latitude substitutes for altitude.
Old 04-12-2020, 02:48 PM   #12
Dahagen
We in Arizona use double bubble reflective foil. You cut to fit windows.
https://www.amazon.com/Double-Bubble...6720779&sr=8-3
dahagen is offline   Reply With Quote
Old 04-13-2020, 09:41 AM   #13
Wolverine 1945's Avatar
Get a roll of Reflectix, and make shads for all windows with cardboard !!!
Wolverine 1945 is offline   Reply With Quote
Old 04-13-2020, 11:54 AM   #14
Originally Posted by rockfordroo View Post
Thanks, I saw those before. I was a little concerned about extreme heat building up between the plastic sky-lite and that insulator in the extreme southern heat. And possibly warping the plastic. Any experience with that?
Thanks again.
Old 04-13-2020, 12:00 PM   #15
NMWildcat's Avatar
Thanks again.
We have used those for years. We are frequently in Scottsdale during the 110 days. Never warped anything, but sure cut down on the heat.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 04-13-2020, 09:07 PM   #16
Lets go camping!
str8t six's Avatar
i painted my skylight white. that way it allows in some sun but keeps the heat from penetrating as much.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 04-15-2020, 09:27 PM   #17
I spend my summers in the UP of MI and it is never to hot. I also have three ACs in my 42 ft fiver.
whj469 is offline   Reply With Quote
Old 04-16-2020, 08:44 AM   #18
I used a high quality primer, then 4 coats high quality white paint !!!
Should also make the plastic last longer !!!
Old 04-16-2020, 08:52 AM   #19
ben31's Avatar
Also, don't let your A/C decide the fan setting for itself. Set in on High during the day, to keep the air flowing. If you have two A/Cs, set them both to, at least, Medium. If you only have one speed, set it to on, instead of auto. You want the air to keep circulating. It helps our quite a bit.
If we leave the A/C on auto, it warms up quite a bit. As soon as we set the fan to high, it drops the temperature by at least 7 degrees.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 04-16-2020, 10:38 AM   #20
tonyz1's Avatar
We have one of the vent pillows in our regular vent that seems to help a lot, although it doesn't have the reflective back. It won't fit in either of our two skylights and haven't been able to find any the right size so far. Been thinking seriously about trying to just make a couple up myself, but me and sewing machine might not be a pretty picture. Just in case anyone knows of some made for the skylights, please let me know.
Tony & Brenda
2017 Ford F-250SD 6.7 Power Stroke
2018 Flagstaff 29KSWS
Happy Camping!
tonyz1 is offline   Reply With Quote
