I was wondering if anyone has accessed the unused area behind the TV and fireplace (entertainment center). I need to get into this area to figure out how to add wiring and to figure out where to drill through the side of the trailer to install a porch light. I am stumped!
Probably right, with the entry door open anything mounted in the area I was thinking about would be blocked by the door. Plus your recommendation would allow me to use just one light under the awning (we really dislike the blue LED strip)
You could replace the blue led strip with another one that you could dim and change the colors. https://www.boogeylights.com/
Or a second choice might be to use the led strip light power to power a new 12 volt porch light. That way you could use the existing switch.
__________________ Craig & Cath
