Old 07-14-2023, 08:43 AM   #1
No power outlets
We have a 2022 Impression 315MB and there are no power outlets in the front living slide. Does anyone know if this is normal?
Psalm22 is offline   Reply With Quote
Old 07-15-2023, 08:22 AM   #2
Indy815's Avatar
We have a 290 VB. There are no outlets in our slide. I use a power strip that is about 8 ft long.
Indy815 is offline   Reply With Quote
Old 07-15-2023, 08:46 AM   #3
Thurman's Avatar
A few years ago I had a TT with two (2) slides, one the living area and the other the dinette area. Neither had electrical outlets. I added two (2) 120vAC outlets with USB outlets built in to both slides. I used shallow surface mount boxes and wire conduit running from the floor up to the boxes. I placed the boxes higher than normal so I wouldn't have to bend over to reach them. I tapped into a 120vAC line I found under the TT, ran 14/2 with ground flexible cord following the 12vDC wires for the light in the slides. By following the 12vDC wires that gave plenty of room for the new wiring to flex when the slides moved. This set up worked well for us.
Thurman is offline   Reply With Quote
Old 07-15-2023, 10:46 AM   #4
Now that you've got an answer and a solution...
Welcome to the forum!
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 07-26-2023, 09:04 PM   #5
Thanks everybody! I guess this is normal, I thought they were forgotten during construction.
no power, power
