Originally Posted by bobcloughjr
How did you beef up your wall?
I took a piece of 3/8" plywood and measured it roughly 2" larger than the hanging bracket, on all 4 sides. Then I took contact paper that matched, as close as could be, to the TT wall and wrapped the plywood, then hung it with 4 short lag screws. All the while making sure not to protrude through into the bathroom side of the wall.
By doing this I was able distribute the hanging weight more securely across the thicker plywood instead of using just 4 screws into the flimsy wall.
Worked great. Never had to worry about the TV coming down while traveling.
