Old 03-21-2021, 05:30 PM   #1
Battery disconnect switch?
2021 FR Salem FSX...
IF my trailer had a batter disconnect switch where exactly would/should it be? I've traced the wires from my battery on the tongue to underneath the trailer where they go inside and don't see anything. I'm fairly certain this trailer does not have a disconnect but want to make sure I'm not missing anything obvious.
Also, would you all suggest I install one?
asl20bball is offline   Reply With Quote
Old 03-21-2021, 05:46 PM   #2
Always Learning
If you don’t have one, I absolutely recommend one unless you’re going to be plugged in 24/7. Anytime you put your RV into storage, you should disconnect the batteries otherwise parasitic draws will run it down until it’s deader than dead.
Old 03-22-2021, 06:48 AM   #3
SeaDog's Avatar
X2 Look under with propane tank rack on the drivers side.
Retired Navy
2016 Flagstaff 26 FKWS
battery, battery disconnect, switch
