Old 04-09-2020, 11:09 AM   #1
Brand New Salem Hemisphere 356QB; Questions/Advice
All,
I purchased a 2021 Salem Hemisphere 356QB from RV Nation in early March 2020. We immediately took advantage of some social distancing via a trip to Gulf Shores (deserted campground and isolated). It's my first real trip, and I've uncovered a few issues/questions:
1. The oven does not seem to light. The stove burners do. I don't hear or smell gas getting to the oven, and the light function does not occur. Any ideas why the burners could be getting gas, but not the oven?
2. The pre-wired Furrion shark fin camera connection does not work. I get no power to the connection in the rear (yes, trailer harness hooked up and lights on). I do see a little "flicker" in the trailer lights when plugging a camera in. I may have to hard wire to the lights?
3. I'm not in love with how "deep" my awning extends in comparison with others I've seen. I'm considering adding one of those shade netting thingamajigs to mine. How do they attach? Is there some sort of special connection point on the end of the awning?
mspeicher73 is offline   Reply With Quote
Old 04-11-2020, 08:29 AM   #2
Missing Link
cyclepuck's Avatar
Congrats, we're picked up a2020 356 in July. For the stove the pilot light needs to be lit manually then it should work fine.
I had the same issue with pre-wired camera. Ended up connecting new power wire to lights. Easy fix.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 04-11-2020, 09:04 AM   #3
SeaDog's Avatar
Your awning tube has an aux slot that you can run the shade screen in. You might consider installing awning poles to keep everything in place once your setup.
Retired Navy
2016 Flagstaff 26 FKWS
Old Today, 12:56 AM   #4
USMCbh1983's Avatar
How is it so far? Iím looking at this model. What are your thoughts?
In search of an RV....and a truck now.
I got the truck now. Went from a 2013 Ford F-150 FX4 Supercrew with 1159 payload to a 2017 Ford F-350 Lariat Supercrew with 3800 payload.
I need an RV now!
USMCbh1983 is online now   Reply With Quote
hemisphere, salem
