Fair Weather Camping
When I bought my '21 FR Salem 177BH I had no dreams of wintering in Alaska, but I thought I could use it a bit more of the year. It has these thick plastic panels (not cora-plast) covering much of the underbelly. The one under the FW tank bows down and is right up against that tank so I'm not sure if it's safe to place a tank heater in between for fear it might melt the panel. There is precious little spray foam insulation around the dump tubing and the panels move around way too easily to call it air-tight. And I doubt the sloppy cut wholes in the flooring count as furnace heated ducting. When I looked throughout the walls and spaces leading to the toilet, outside and inside shower, and kitchen sink I found numerous opportunities for water or sewage to freeze. After reading the posts I'm thinking of wrapping pipe insulation around every plex tube I can find, adding a tank heater for each tank, wrapping the waste tubing with insulation and heated tape. I also wonder if blowing in some loose insulation above the underbelly panels and sealing it better would help. If anyone could please give me some advice I would really appreciate it. The last time I had a vehicle that was only usable 7 months of the year it had two wheels!
