Old 10-10-2024, 12:47 PM   #1
Floor replacement
I apologize if this question has been asked, but I cannot find the answer.
We need to replace the entire floor on the slide out in a 2019 32 BHDS Salem
Can anybody give me the exact dimensions of the slide out floor.
The entire floor needs to be replaced as it is all rotted out and got water damage.
Thank you
HazelJ is offline   Reply With Quote
Old 10-12-2024, 10:58 AM   #2
Boss Ox & Drovergirl
oxcamper's Avatar
Are you repairing it yourself or taking it to a facility (ie dealer or repair facility)
if you're removing everything from the slide, can you take the measurements?
The unit is only 3 years old, going a bit farther, did you determine the source of the water damage, cause if that's not fixed, then you'll be dealing with the problem again.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
floor, replacement
