Trying to put a TV in my new 161 QK and the factory bracket is set too high for the TV to be slid down into it. I found a few videos that talk about a metal plate on the other side of the wall as a "backer" for TV's:
(chapter 3)
(chapter 2)
I'd like to either lower the bracket location but I'm not sure what's holding up that metal plate and I was wondering if anyone knew. I'm concerned that if I unscrew everything the metal plate the wall may be depending on those screws and fall down. I wouldn't expect that to happen but just wanted to check before resetting the bracket. One other option I was considering was installing a full-tilt swivel mount but I'm not sure if the mount will slide down into the factory bracket. Any suggestions?
