Old 12-18-2019, 04:44 PM   #1
Hemisphere 273RL TV mounting question
The board that the 50" Jensen TV in the entertainment center mounts to came loose. The screws holding it to the finished frame trim are not very long and some seem to have missed or almost missed the frame and pulled loose. I removed the five screws from the frame but could not get it free. There appears to be a strip of wood along the bottom keeping it from moving back and coming free. Not wanting to damage anything, thought I would ask if anyone else has had this issue?
Trailer traveler is offline   Reply With Quote
Old 01-04-2020, 08:13 AM   #2
Here is an update with the resolution. Since the trailer was still under warranty, I took it back to the dealer. The only way to reattach the board is from the back by removing the outdoor kitchen. We agreed on the solution that I was going to use if doing it myself. A frame was made that fit inside the existing frame of the TV center. The back board was attached to that frame and the new frame was then attached to the sides, bottom and top of the entertainment center frame.
hemisphere, mount, tv mount
