Old 06-30-2019, 08:45 PM   #1
runner48's Avatar
Hot water Concern
I have a question in reference to a possible issue with the water heater, not sure if it is. Anytime the hot water valves are turned on in the shower and kitchen sink, a noise is heard and the water pressure trickles out, I have to turn the cold water valve on so a sufficient amount of hot water also emits out. Any suggestions as to the reason why this is occurring?
runner48 is offline   Reply With Quote
Old 06-30-2019, 09:07 PM   #2
XenoRev's Avatar
Is this on city water, or on your tank and pump?
Sounds like a vacuum forming in the line, somehow.
2018 Salem 27DBK
2004 Ram Quad 1500
Days past:1996 Coachman Capri-Ruby Ed. 27DS
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3
XenoRev is offline   Reply With Quote
Old 06-30-2019, 09:21 PM   #3
Oaklevel's Avatar
Check the position of the winterizing valves behind the water heater to make sure that they are turned correctly.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 06-30-2019, 09:35 PM   #4
runner48's Avatar
I am on city water, I have never winterized my rig, but will check the valves.
Old 06-30-2019, 10:24 PM   #5
Also verify that your outside shower valves are fully closed. If they are open, but the cut-off button on the shower is pushed, it will act the same as if the WH bypass valve was open.
2011 Traverse LT, 3.6L, FWD
Old 06-30-2019, 11:58 PM   #6
Check the check valve at the water heater. Could be failing or plugged with something?
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 07-03-2019, 06:38 AM   #7
XenoRev's Avatar
Thinking still on this, but it sounds like you might have the 3 valve bypass setup on your water heater, and the middle valve is turned the wrong way...
2018 Salem 27DBK
2004 Ram Quad 1500
1986 Jayco1016PUP
Old 07-03-2019, 07:32 AM   #8
Not all WH's have 3 valves, not all have check valves. I've attached a drawing of the many ways I've seen the valves plumbed on this forum. Good luck.
Old 07-28-2019, 08:33 AM   #9
THIS
campingguy is offline   Reply With Quote
hot water, water
