11-24-2017, 02:20 AM
#41
Originally Posted by NMWildcat
No disconnect at all. Some folks are talking about no/partial hookups (like you), and others are talking about full hookups. My rig in a FH site provides comfort exactly like my stick house. I just have to refill propane more often
No way.
11-24-2017, 06:09 AM
#42
It looks as if the original post has been modified! ! To answer this "how long does your hot water heater last shower " I hope I have Not taken my Last Shower"! Youroo! !
11-24-2017, 07:41 AM
#43
Originally Posted by Ttramp
No way.
I agree with him, between me and my wife we have showered for 20+ minutes straight each, I shave every shower and my wife shaves her legs occasionally. the only time in between for recovery is the few minutes she takes to dress and brush her teeth because we shower at night. Also there is no order who goes first.
I’m wondering if the flat cut in/out thermostats could be moved to a better location on the tank to get the water hotter in the tank. Closer to the bottom as heat rises?? Maybe certain tanks have them in different locations all I can say is I’m happy with the temp on mine.
11-24-2017, 08:01 AM
#44
Georgia Rally Coordinator
Originally Posted by HESN22
We have a 5th wheel ... we heat water with gas ... lasts 10 - 15 mins ... and that's a moderately hot shower ... have long hair ... lots of time to do what needs to be done and have never run out of hot water ...
Yep and I bet you have a 10 gal water heater and take Navey showers Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
11-24-2017, 09:43 AM
#45
No way.
Way
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-24-2017, 10:06 AM
#46
There is no edit history for the original post. The system thinks it has not been modified.
11-24-2017, 11:03 AM
#47
Originally Posted by TexasZ71
I had that problem when I first got it no bypass if I remember right. Simple 2 valve system
But now its seeing how long i can keep hot water going before it gets cold, just to keep her happy, when she is over. I am hoping turning the propane on prior to, will help out tremendously.
Originally Posted by Mr. Dan
Even a two valve system has a bypass function. There are many instances of same here on this site. It just means 1 or both valves are 3-way instead of 2-way (on/off). You should still check to assure yourself that one is not allowing hot and cold water to mix.
Mr Dan is right. See attached, page 2. I'm betting you have Option 2a, 2b, 3a or 3b. It would be pretty difficult to winterize without a bypass, unless you filled the water heater with antifreeze.
2011 Traverse LT, 3.6L, FWD
11-24-2017, 06:37 PM
#48
Well we tried leaving propane on and still got cold. But we can leave hot side on and it stays hot. So that leads me to believe that the water isnt mixing. Like it was prior to getting my trailer. Cant remember but i think this is the correct way for my system.
2018 forest River salem 27dbk bumper pull
2016 chevy silverado 1500 z71 5.3L 6 speed 3.42 gears
11-24-2017, 08:45 PM
#49
That's correct. To winterize, rotate both valve handles so they are aligned with the white bypass line.
11-24-2017, 10:02 PM
#50
How long does your hot water heater last shower (minutes)?
Thanks i am still not sure why it’s getting cold quickly? I know both electric and propane works since i tested them out individually. After getting the valves right way prior to all this (i think i did that on day 2 of ownership)
11-24-2017, 11:02 PM
#51
Ok i have a 6gal hot water heater i think it can supply 18gal on electric+propane? I know it has a quick recovery. But when showering is when its needed the most.
Anyway i guess since me and my girlfriend takes different length of showers it got cold on her with in 6min or so. That was on electric only. So i kicked it on propane and still no change. I don’t recall using the hot water prior to.
I never had this problem since i run electric only and 99% of the time is 5min. And I know it works.
I don't know where you're getting the 18 gal figure. Any such figure would need to include an assumed flowrate and minimum temperature.
You might want to get a milk jug and measure your flow rate; then you get get an idea of how long it might last. Assuming you're using about 1-1/2 gal/min, your water heater is going to run out at 4 min, ignoring any cold water coming in and mixing with what's going out. With electric and gas on, you MIGHT get another minute out of it.
Getting 6 min implies your flowrate may be closer to 1gpm than 1-1/2gpm, but it's still going to get cool fairly quickly.
Teach your GF to take Navy showers.
Another option: Assuming you have a Suburban, it comes with 130 deg F thermostats. You could replace them with 140 deg F thermostats. See Post #7 here:
http://www.forestriverforums.com/for...re-110160.html
11-24-2017, 11:28 PM
#52
Thank ya, i have told her to turn the shower head off when washing, and it helped some.
11-25-2017, 04:17 AM
#53
2018 Rockwood 2703WS
We solved this problem by adding an on demand water heater in addition to the factory gas only HWH on our old Starcraft. We are waiting on delivery of the new Rockwood, and will have to test the HWH capacity before we consider modifying the new TT with an on demand.
Endless on demand hot water - Starcraft RV Owners Forum
2014 Ram 2500 4x4 diesel
guarded by our Jack Russell
11-25-2017, 09:57 AM
#54
Thanks for the link.
11-30-2017, 03:26 AM
#55
Global Nomad
One of the great things about a tankless hot water heater is NO MORE NAVY SHOWERS.
Steven J. Scheinin
2015 RAM 3500 4X4 6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS (Center Kitchen Three Slides)
11-30-2017, 01:42 PM
#56
Could a tankless system be added in place of mine?
11-30-2017, 02:18 PM
#57
You better always have hookups, to make a tankless WH worth it.
We dry camp nearly all the time, so a tankless isn't worth it to us.
11-30-2017, 02:19 PM
#58
Ya i doubt this thing is moving any time soon.
11-30-2017, 02:21 PM
#59
Disagree. We drycamp 80% of the time. Definitely prefer tankless.
11-30-2017, 03:34 PM
#60
How do you deal with all the gray water generated?
