11-21-2017, 12:29 AM
How long does your hot water heater last shower (minutes)?
Ok i have a 6gal hot water heater i think it can supply 18gal on electric+propane? I know it has a quick recovery. But when showering is when its needed the most.
Anyway i guess since me and my girlfriend takes different length of showers it got cold on her with in 6min or so. That was on electric only. So i kicked it on propane and still no change. I don’t recall using the hot water prior to.
I never had this problem since i run electric only and 99% of the time is 5min. And I know it works.
2018 forest River salem 27dbk bumper pull
2016 chevy silverado 1500 z71 5.3L 6 speed 3.42 gears
11-21-2017, 12:55 AM
I had this exact same issue. I posted on here too. Although I haven’t been back out in my trailer since posting to try out what responses I got.
Most of the responses I got said to make sure the bypass valve on the water heater is off all the way so the water isn’t blending. It’ll be a couple weeks before my next trip to see if that was the cause. I was getting 4-5 minutes at best in my shower.
11-21-2017, 01:59 AM
I get about 4-5 mins as well. I have the 6 gal water heater. I added the electric element which I leave on all the time since I am full timing it. I embraced the "combat shower" technique to get the most out of it.
I will take a look at that bypass valve in the morning.
2016 Shasta Flyte 255RS
2011 Chevy 2500HD Duramax Crew Cab Long Bed
11-21-2017, 02:23 AM
Just as confused as you
Another place you will want to check is the outside shower if you have one. If the valves are open and the wand valve is closed it will cause blending of hot and cold just like if your bypass valve is open.
Richard & Jill
11-21-2017, 04:32 AM
There was a Government research study on "Water usage while Showering" this was a Long Term High Dollar study under Strict Controlled conditions! The final documented outcome was "People with Hair use more Water"! Youroo!!
11-21-2017, 04:34 AM
I had that problem when I first got it no bypass if I remember right. Simple 2 valve system
But now its seeing how long i can keep hot water going before it gets cold, just to keep her happy, when she is over. I am hoping turning the propane on prior to, will help out tremendously.
11-21-2017, 06:12 AM
World Wide Wanderer
You only have a 6 gallon water heater...
We do "navy" style showers where you shut the shower head off while soaping up. We can take two showers back to back and not run out of hot water.
Home systems typically have 40 gallons or larger. Some have continuous water heaters. Check the bypass valves and the outside shower, but I suspect you may have to change your showering method.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
11-21-2017, 07:37 AM
Insert witty title here
Aaron
X2
Turn shower head off while soaping up. Turn it on again when ready to rinse. Don't just let it run continuously.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
11-21-2017, 08:21 AM
Originally Posted by timfromma
X2
Correctomundo!
Exactly what wifey and I do; daughter hates the idea, so she always goes to the bathhouse.
2008 Honda Ridgeline
2013 Rockwood Mini Lite
10k Equali-i-zer WDH
Tekonsha Prodigy P2 Brake Control
11-21-2017, 08:23 AM
Ok I have a fifth wheel but I can’t remember the brand hot water heater maybe suburban, however I do have electric and gas so what I have done is; always keep electric hot water element on and just right before you get in the shower turn on the gas switch and you can pretty much shower as long as you need. If it is colder outside you can insulate the garden hose with nerf tubes from swimming pools. My tank is a 10 gallon but to me it’s no different than a quick recovery 6.. my wife does have long hair and the first time out I was good and she ran out of hot water. Later I found out the gas solenoid was not getting the 12 volt trigger voltage needed to open the gas valve. Once fixed it works like a charm.
Hot water is hot from electric and as soon as the cold is introduced the gas side kicks on and that’s all once your done showering simply turn the switch off.
11-21-2017, 08:29 AM
Tex, where did you find the 18 gallon figure? I'd like to study that a little more.
11-21-2017, 08:30 AM
As mentioned- turn on both LP and electric when showering.
My surburban WH has a sticker that says what the recovery time is for electric and LP and combined. Combined the recovery is 1/3 the time as electric alone.
So turn on that LP if you want a much quicker recovery!
If it's warm weather and the incoming cold is not so cold you probably won't run out of HW.
If it's colder outside and the incoming is cold then you may need to take Navy showers. We can take back to back navy showers and not run out even when it's 33 outside. We do place a small electric heater on the floor near the bathroom door to add extra warmth to the room. This helps so your wife won't feel as cold during those times the water is off while lathering...
Good luck.
Remember- it's all part of the adventure!
Peace!
Dan & Rita D
11-21-2017, 08:53 AM
It is what it is, however, going to an Oxygenics shower head will give the impression that you've picked up pressure and you can go to a lower volume setting on the faucet. I switched out my faucet as well to a single handle style (Dura Faucet from Amazon) that allows me to get the temp and lower flow rate dialed in pretty quickly. If you are on the potable tank it really stretches your water supply out and hence your hot water.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
11-21-2017, 08:58 AM
We only use LP when boondocking. I don't see the need to use my LP when I'm paying for electric. We find that if we space out our showers by 15 - 20min, we never run out of HW.
11-21-2017, 11:33 AM
Reading this thread reminds me how glad I am to have a perfectly functioning on demand water heater . After 10 days of Navy showers while boondocking, we went to full hookup park and we both luxuriated in a 20 minute, hot shower. Now if we could just find a rig with a shower big enough for two!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
11-21-2017, 01:43 PM
I am honestly not sure where I found that information. I do remember dealership had 18gal so i done some looking and its part of the quick recovery feature?
11-21-2017, 01:48 PM
Lucky dog... still on the honeymoon, eh?
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
11-21-2017, 01:51 PM
Aaron
X3
11-21-2017, 01:56 PM
Navy Shower
I have sometimes wondered at the disconnect here when discussing showers in an RV. A simple fact of life in most factors in RV living is that this is simply NOT your stick home. You can't leave the lights on and the heater running 24/7, and you can't luxuriate in the shower for 15 minutes. Continuous hot water doesn't mean a continuous supply or an infinite grey tank.
Beds are different, steps are different, space is different, storage is different, and the water heater is different, and so is the waste container. Not only do you have a limit on hot water, that is far less than at home, you also have a limit of how much water you can dump into your grey tank.
Adjustments to these factors are a fact of life. I can get a great shower without running the water continuously, and do so. So does my wife. We can take showers one right after the other, and never run out of hot water.
My goal is proper sanitation, and infrequent trips to the dump station.
Not that difficult.
11-21-2017, 02:04 PM
No disconnect at all. Some folks are talking about no/partial hookups (like you), and others are talking about full hookups. My rig in a FH site provides comfort exactly like my stick house. I just have to refill propane more often
