Originally Posted by spiker
I have a Hemisphere GLX 272RL. Has the Residential fridge that runs on eclectic only. Came with a inverter, Xantrex Freedom X 1200. Can I use this inverter to power the outlets in the bedroom? when off shore power? It seems to be only running the fridge now. Thanks
You can but will have to do some rewiring to make it work and hopefully the wiring to the bedroom is accessible somewhere to where you can cut into it and tie it into your inverter.
Are you looking to use CPAP machines in the bedroom?
If so, there are better ways than using the inverter.
