Can you raise the trailer to where wheels are off ground and then put blocks of some sort under tires? Trailer is at permanent sight and has its own dump hook up. The problem is there is almost 0 fall for the dump pipe and I would like to raise it so it has more fall. its a 31ft bunk with super slide.
Yes. It’s easiest to hook it to a truck and pull it forward. Put blocks down and back it up onto them.
Barring a truck, you could likely do it with jacks.
