[QUOTE=cburchel;1425841]Quick question. have you winterized yours before? Im curious on the location of the low point drain? We used it over the weekend but when we got back I went ahead and blew the lines out and dumped some antifreeze in the drains just to be on the safe side. But im still curious on the low point drain.[/QUOTE
I have no idea about low point drains. I drained the fresh water tank, removed the anode rod in the water heater to drain it then turned the bypass valves to the water heater (you have to remove the panel inside the compartment next to the water heater to get to them) and added antifreeze to the fresh tank. Then I ran the pump and opened the faucets (farthest from the pump first) until antifreeze came out all the faucets. I'll find out in a few weeks if it worked.
On a side note, I'm taking mine back to the dealer on Friday to get the slide worked on. They said it had a problem and "repaired" it last time it was in for warranty work. Now it jumps while moving in or out. Hopefully it's just an adjustment.
