Old 05-18-2020, 02:29 PM   #1
camplight's Avatar
Newbie question - Getting hot water while using only water in fresh water tank
Please don't roast me this question but how can you get hot water while only using fresh water tank water? How will the WH fill up? I am confused how this works so if someone didn't mind explaining this to me, I would greatly appreciate your help. 2016 Salem Hemisphere 356 QBS. I have spent a day searching for this answer with no luck.
John
2011 Dodge Ram Crew Cab 2500 6.7L 4x4
2016 Salem Hemisphere 356QB
Andersen Ultimate Hitch (over gooseneck ball)
camplight is offline   Reply With Quote
Old 05-18-2020, 02:37 PM   #2
bikendan's Avatar
First, before you turn on the WH, you make sure there's water in the WH, by running the pump and opening the hot side of a faucet.
After that, it's no different than the process when on city water, other than you leaving the pump on when needing water.
Equalizer WDH
Old 05-18-2020, 02:41 PM   #3
Had the issue last summer in Houston.
Did the chicken without a head act for a day.
Duh! Water in Houston from the taps can reach 90 degrees! Gag. In Ohio we bury water lines deep. There they donít.
Another time, the outside shower was turned off by the spray nozzle. If the valves/faucet are not off it bypasses to the cold water.
Same is true of the shower if you can turn the flow of water off with the shower hose!
There, two good ones.
And in the hot water heater if the bypass valve between the two lines is cracked or broken. Or not closed.
tomkatb is offline   Reply With Quote
Old 05-18-2020, 02:49 PM   #4
camplight's Avatar
So simply running the pump and opening a hot water faucet, this will fill the WH with water then I can turn it on? How do you know the tank is full, by water coming out the faucet?
John
Old 05-18-2020, 03:04 PM   #5
cboss's Avatar
If it comes out the hot water faucet the tank is full.
Same applies when hooked up to city water.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 837
cboss is online now   Reply With Quote
Old 05-18-2020, 03:08 PM   #6
bikendan's Avatar
UNLESS the WH is in bypass mode. But if the OP's hot water was working on city water, it shouldn't be in bypass.
Equalizer WDH
Old 05-18-2020, 03:10 PM   #7
cboss's Avatar
Sorry. You are correct!
Craig & Cath
Old 05-18-2020, 03:12 PM   #8
camplight's Avatar
Thank you all for the responses. Sorry for such a simple question. Happy camping!
John
Old 05-18-2020, 03:18 PM   #9
cboss's Avatar
On this forum there is no such thing as a simple (or dumb) question!
Everyone on here wants to help everyone else.
The really knowledgeable folks on this forum were not born with that knowledge, it's experience and they like to share it.
I learn something new almost everyday.
And remember "search" is your friend.
Craig & Cath
Old 05-18-2020, 03:35 PM   #10
GoneSouth10's Avatar
And remember the Golden Rule of FRF: It's a lot easier to ask a dumb question than to fix a stupid mistake!!
2015 Berkshire 34QS
GoneSouth10 is online now   Reply With Quote
Old 05-18-2020, 04:10 PM   #11
Maybe this will help...
Days Camped: '17=30 '18=51 '19=58 '20=83
Old 05-18-2020, 04:40 PM   #12
Be sure to go to the outside and open the WH cover. Pull the pressure relief valve lever to see if water comes out.
If your bypass valves are still in the bypass setting your water will go right past the WH and come out the hot side of the faucet even thought no water is actually in WH.
MtBiker is online now   Reply With Quote
Old 05-19-2020, 01:49 PM   #13
Thanks for the plumbing schematic! Does anyone know if the FR Flagstaff ePro 14fk has the connection to automatically fill the onboard freshwater tank from the city/shore water connection? Since I've not actually ever seen a schematic for our TT, I really don't know and we've never really taken it on the road since we bought it last Fall. I could experiment, but the TT is in a storage lot and I thought I would be lazy and ask here.
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
Sarahcat is offline   Reply With Quote
Old 05-19-2020, 02:48 PM   #14
bikendan's Avatar
Seriously doubt it.
I've personally never seen such an automatic setup. Maybe a valve lever to flip, which I've seen on higher end 5th wheels or Motorhomes. But not on small TTs.
Your E Pro most certainly has a FW tank fill port and a separate city water hookup. In fact, if your FW tank fills up when on city water, you have a check valve problem.
Equalizer WDH
Old 05-19-2020, 04:53 PM   #15
Adrian Gordon's Avatar
Next time you're out at your TT, take a picture of the water hook up arrangement and post it. My Leprechaun motor home has a single water connection. It fills the FW tank or provides city water depending on what position the valve is in. Just select which one you want, preferably before you stand around for a half hour bemoaning how low the pressure in campground water system must be because your FW tank hasn't filled yet only to discover that the lever is in the city water position.
2018 Coachmen Leprachaun 210RS with DW, a German Shepherd and the cat.
Adrian Gordon is offline   Reply With Quote
Old 05-20-2020, 07:20 AM   #16
BillyBass's Avatar
Your second question when the pump quits running the water tank is full
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 4 nites
BillyBass is offline   Reply With Quote
Old 05-20-2020, 07:26 AM   #17
Mr. Dan's Avatar
The pump won’t stop running if a hot side faucet is open as suggested.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 26; booked = 42
Old 05-20-2020, 07:47 AM   #18
BillyBass's Avatar
Originally Posted by Mr. Dan View Post
The pump wonít stop running if a hot side faucet is open as suggested.
Bc it is calling for water .what am I missing in this question. Anytime I use my fw tank When using hot or cold my pump comes on
Old 05-20-2020, 08:03 AM   #19
BillyBass's Avatar
Do you have the valve open to the tank.
Old 05-20-2020, 08:14 AM   #20
camplight's Avatar
My original questions have been answered. I was not aware that the pump would fill the HW tank. All trips we took so far were hooked up to water. Thank you all for the help and advice, much appreciated.
John
hot water, water tank, water, newbie, fresh water, tank
