Outside kitchen
We purchased a 31KQBTS brand new off the lot. Today I went out and ran water through the lines and water heater to check for leaks. Found the outside kitchen leaks from the cold water hose, I'll throw some pipe dope on it and tighten it down. It should be fine. What's got me baffled is, the water drains extremely slow. I crawled under the unit and checked to see if there might be a valve closed for some reason. Nope. Drain line runs straight into the gray tank. I took the caps off and opened all the drains valves. Nothing came out. Am I missing something?
