We are having an issue with excessive heat coming in the RV.
It is the summer time and the outside temps are in the high 90's/low 100's. So we are not using the furnace.
Heat is coming up from the hole in floor of the cabinet where the furnace is. It's the hole that the ducts go through. The hole is fairly large.
How do i seal it to prevent that excessive heat from coming in the RV?
We have the same issue with the closet in the bedroom that has a joining wall with the bathroom. There is a fake wall that the washer butts up to. Behind that wall is a large opening that massive amounts of heat is coming in from.
Any solutions on how to prevent the heat from coming in? Or cold in the winter?
Below are pictures of the closet and I could not get pictures in the cabinet where the furnace is.
