Originally Posted by katkt
Somebody on here posted a link to a Goodyear article, regarding tire storage. When they are mounted on a vehicle and carrying weight, they encouraged inflating them about 10psi above normal, IIRC. Just make sure to deflate them to normal, before hitting the road again
I just read the same thing in a doityourselfrv.com article:
“Tire protection
The cold can wreak havoc on your RV tires. Tire care should be a consideration for everyone when RV winterizing. Most tire manufacturers recommend increasing the tire pressure when in storage and/or removing weight on the tires.
You can pump the air pressure up to the sidewall maximum, or even up to 10 psi over, and you can use jacks to partially lift the RV frame to reduce the weight on the tires.”
Rick & Stephanie
2019 Toyota Tundra Crewmax TRD Sport
2018 Salem Cruise Lite 241QBXL
Whenever I feel blue, I start breathing again.
