Old 11-13-2020, 10:53 AM   #1
Tire storage
How does everyone store their tires? Is there a benefit to getting them off the ground? What about letting pressure out? Do I need to have something between tire and ground?
Thoughts?
BTB517 is offline   Reply With Quote
Old 11-13-2020, 10:56 AM   #2
hack522's Avatar
My Roo is on asphalt so not worried about it. If it was cement, I would have a barrier to prevent the deteriorating effect from I believe the lime.
hack522 is offline   Reply With Quote
Old 11-13-2020, 11:43 AM   #3
Jim34RL's Avatar
When my trailer is in the storage lot, I place a 2x8-6 feet long under each set of tires, regardless of surface. The tires are than covered with a wheel cover to help prevent the rubber from deteriorating due to UV light from the sun. I also use tire dressings for RV tires made by Meguiar's.
By doing this I was able to get 5 years use out of my factory tires before replacing them.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
storage, tire
