Old 12-01-2020, 03:24 PM   #1
Tv mount bolt length
I am going to be mounting a TV in my back bedroom. Does anyone know how long of bolts I should use? I am worried about going through to the outside.
BTB517 is offline   Reply With Quote
Old 12-02-2020, 09:42 AM   #2
SeaDog's Avatar
I would use nothing longer then about 1.25 inches
Retired Navy
2016 Flagstaff 26 FKWS
Old 12-02-2020, 01:57 PM   #3
Head Rambler
The wall is going to be about 1Ĺ" thick so I agree with Seadog, nothing longer than 1ľ" and probably closer to 1".
Is there a "tv backer" sticker on that wall?
Gotta go campin!
Old 12-02-2020, 02:50 PM   #4
U.S.ArmyVeteran's Avatar
What he said:-)
Also, I would not mount to an exterior wall. Unless, you have a factory installed "backer". Even if their is a sticker. Verify with a stud finder.
If your not sure of what is in the wall and you mount it anyway. Remove TV before traveling.
U.S.ArmyVeteran is offline   Reply With Quote
Old 12-04-2020, 08:40 AM   #5
MilCop4523's Avatar
we used 1 inch with lock washers the bracket is going to reduce the length of the wall depth for entry. I also predrilled a hole so the wood would not create a small hump in the wall paneling as well (not that you would see it behind the TV.)
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 12-04-2020, 12:09 PM   #6
I used what came with the mount but since there was a window underneath, I backed a screw out that held the valence in place and verified it was longer than what I had.
I think I predrilled one hole in attempts to find the backer near the sticker, and I could never locate anything with the stud finder. In the end I used that hole and self tapped the other without the hole and didnít have any humps that I remember. I may have drilled a small pilot for each, but I wanted the screws to bite.
It has held up with no issues over a few long trips, with bumps along the way, not just smooth road. But my entire setup with the mount weighs less than 10 pounds, so that might have something to do with it. I think itís like 7-8 pounds total. Itís a smaller flatscreen.
{Tpc} is offline   Reply With Quote
Old 12-04-2020, 09:55 PM   #7
Just as confused as you
Scrapper's Avatar
The Lamilux bedroom wall on my tt is barely thick enough for a 1.25 inch screw. Use self drilling self taping 1/2" or 3/4" screws as the backer plate is aluminum. And don't ask how I know the slideout wall is 1.25 inches thick.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Scrapper is online now   Reply With Quote
mount, tv mount
