Old 09-19-2022, 06:43 PM   #1
2017 Salem 27REIS
Underbelly plastic sheeting purpose?
I have a 2017 Forest River Salem 27REIS. The piney squirrels have invaded the plastic underbelly sheeting. I can hear them moving around underneath and sometimes hear them chewing on the flooring. I'm considering removing it to prevent the squirrels from having someplace to dwell now that the temps have dropped. Last fall I crawled under and patched all the holes I could find they had chewed in the plastic but am trying to avoid doing that again as it's time consuming and seems endless until the real cold settles in.
Does this plastic sheeting serve any real purpose other than some insulation to help in colder temps?
BretR574 is offline   Reply With Quote
Old 09-19-2022, 07:20 PM   #2
bikendan's Avatar
Moved thread to the Salem sub-forum since some enclosed underbellies can be for heating the holding tanks by the furnace and some don't.
Sent from my SM-G781U using Forest River Forums mobile app
Old 09-19-2022, 07:26 PM   #3
I think that it helps keep water off the bottom of the rig. Perhaps you could staple something like 'hardware cloth screen' over the plastic.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 09-19-2022, 07:30 PM   #4
It also helps air flow during travel to MINORLY improve towing MPG.
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 09-19-2022, 07:31 PM   #5
Oaklevel's Avatar
If you remove the under belly you may have to tie up some of the wiring. The squirrels may chew up the wiring if nothing is done.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 09-19-2022, 07:44 PM   #6
Isn’t there insulation above the chloroplast ?
Cross-threading works better than blue loctite.
Capacitor is offline   Reply With Quote
Old 09-19-2022, 08:33 PM   #7
2017 Salem 27REIS
That's the major concern I have with them crawling around under there. Last year they chewed the wires for the tank sensors. Not a huge deal but afraid they'll chew something more important.
Old 09-19-2022, 10:48 PM   #8
Some units yes others no.
Some have a layer of Reflectix type insulation.
Days Camped '19=110 '20=116 '21=123 '22=134 '23=93
Old 02-06-2023, 03:32 PM   #9
{Tpc}'s Avatar
If the plastic isn't there, the next attempt by them might be into the trailer?
I'd yank it all down to clean and repair underneath and then put it back up, and fix any damaged spots. But must be some kind of repellant they don't like so Id put that in there, and around the outside of the trailer.
Knowing myself, I'd probably seal the whole thing off as well as I could with some strong sealer, even if it meant harder to work with in the future.
2020 Salem Hemisphere Hyper-Lyte 25RBHL
2022 Ford F150 SuperCrew 3.5 Ecoboost MaxTow
{Tpc} is offline   Reply With Quote
underbelly
