The kitchen slide was adjusted and it works great now. But now I have another problem, but yo the hydraulic front landing gear. When the unit is set up with all slides out after a day the cylinder supporting the 4 slide side retracts two inches than holds. The dealer I went to said they spoke to Lippert and this is normal. Thoughts?
Hi again lugnut here
I'm a heavy duty mechanic in Alberta Canada I work with hydraulics every day.
The hydraulic cylinder could be bypassing or the manifold that houses the one way check valve could be by passing.
There is a problem in your hydraulic system.who ever told you that is normal is very wrong
ALERT FOR 355RE owners: if the right-side door (drivers side) on the bar/cabinet separating the kitchen from the RE comes open during travel it will catch on the kitchen slide-out. This will in turn rip the door off it hinges and cause the kitchen slide to come out of adjustment. At least it will if you are a newbie and not finely tuned to the sound of a slide under stress! Strap these doors shut.
