Old 06-16-2021, 02:29 PM   #1
fifth wheel question
love my 2020 sandpiper 39bark fifth wheel, the only issue I have is hooking up and unhooking I have to use he two step method, back up till the pin box is in back of truck, close tailgate the finish hooking up, otherwise the tailgate will hit the trailer, I did not have this issue with my Jayco fifth wheel, I tow with 2021 ford f-350 crew cab 4x4 long bed. Seem like the pin box is too short or set too far back on the trailer, I have looked into getting a longer pin box but there are not any that will fit the rhino box. I sent an email to Forest River customer service but have not had any response. Has anybody else run into this issue?
gbw21 is offline   Reply With Quote
Old 06-16-2021, 02:38 PM   #2
Georgia Rally Coordinator
aceinspp's Avatar
Any time your hooking up to a 5er you have to drop the tail gate unless you installed a 5th wheel tail gate which you did not mention. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-38
Old 06-16-2021, 02:40 PM   #3
GFAR's Avatar
Does this truck have the new puck hitch type hook up? Can you slide the hitch back?
GFAR is offline   Reply With Quote
Old 06-16-2021, 02:46 PM   #4
the truck does have the factory puck system, I have a b&w companion fifth wheel hitch and do not have a fifth wheel tailgate, did not have to raise the tailgate with my jayco fifth wheel
Old 06-16-2021, 02:52 PM   #5
What forward/rearward position are the arms for the hitch head mounted in? There's about +-2" of room there to adjust.
With my B&W sitting in my factory Ford pucks, I have the arms mounted all the way rearward and can hitch solid without having to raise my tailgate.
Days Camped: '18=51 '19=58 '20=110 '21=94
Old 06-16-2021, 03:08 PM   #6
GFAR's Avatar
I do not have to raise tailgate to hitch. I have 3500 chevorlet which shouldnít make a difference. After I hook up I shut tailgate. Has got to be an adjustment I would think, if I had to hook up like that I would have already hit front of rv! Lol
Old 06-16-2021, 03:31 PM   #7
i do have the arms mounted as far rearward as possible. I just taps the the trailer.
Old 06-16-2021, 05:02 PM   #8
Always Learning
OP means that the tailgate is down as they start backing up.
After the kingpin clears the tailgate, they have to go put the tailgate up because if they don't, the tailgate will hit the trailer.
Checkout my site for RVing tips, tricks, and info | Was a Fulltime Family for 5 years, now we're settlin' down for a spell
Old 06-16-2021, 05:57 PM   #9
NMWildcat's Avatar
Do a search for Rhino pin box in this forum or others. Several reports of others having your tailgate clearance problem with the Rhino.
Scott and Liz - Southern NM
Old 06-16-2021, 06:08 PM   #10
asr524's Avatar
Post a picture of your king pin/hitch box. I have a different RV but similar truck...my tailgate is close but doesn't hit if im backing straight. The corner will if I am at a decent angle to the RV.
2021 Wolfpack 315Pack12
2014 Ford F350 6.7L Diesel
2019 Indian Chieftain Dark Horse
asr524 is offline   Reply With Quote
Old 06-17-2021, 07:42 AM   #11
Thank you, I did find where other people have had the same concern and looks like sandpiper stepped up. Sent an email to sandpiper. We will see what happens.
Old 06-20-2021, 08:44 AM   #12
Gbw you have the new rhino box king pin. I have it on my sierra, it's the same camper as the sandpipers. Call Forrest River, I spoke with them. They are recalling alot of their early built units because their king pins were too short on their new rhino boxes. They now make a longer rhino box which they will give you for free, u might have to go through your dealership service center. But FR is awauof the issue and replacing those shorter rhino boxes.
cuttymcgavin is offline   Reply With Quote
Old 06-20-2021, 08:57 AM   #13
acadianbob's Avatar
That's a crazy error. How long have they been in this business?
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 06-21-2021, 08:47 AM   #14
I did talk to Forest River and they are working with me to resovle my comcern
Old 06-21-2021, 04:27 PM   #15
Great!
Keep us posted, good or bad.
fifth wheel, question, wheel
