Old 12-11-2017, 11:47 AM   #61
Wolverine 1945's Avatar
Originally Posted by rockfordroo View Post
You could do that, but I'm thinking the air flow may make you feel cooler than if you didn't run it. Only way to know is to try it.
Very possible !!!
When you first turn Heat Pump on,,, very cool air to start with !!!
Wolverine 1945 is offline   Reply With Quote
Old 12-11-2017, 11:54 AM   #62
Originally Posted by Wolverine 1945 View Post
So can we use the A/C fan to blow the heat from the space heater around ???
With ours T would try using the Heat Pump setting ???
The A/C fan will not circulate air thru the belly of the trailer which the furnace fan does.
Old 12-11-2017, 12:08 PM   #63
Very True !!!
heater
