Flickering indicate failure on LEDs. They will go out soon.
Those fixtures are meant to be replaced as a unit, which can be pricey, but if you are handy with a soldering gun, you can order generic 2 pin LED bulbs (I get the soft white output with the desired lumens for my application), snip the wires on the old bulb and solder in a new bulb for a fraction of the cost of replacing the entire fixture. Being a retrofit, I have to use a small wire tie to hold the bulb in place in the fixture.
Mark & Susan
Former MBS 24R and 2401W Owners
Just recalibrating our camping set-up for now!
