Hi thank you for your reply. I didn't think I would hear back until today. You are right. the lamp socket has two points of contact. I ordered the type it calls for 1076. The previous owner had some halogens that have one point of contact so thats probably why the fuse blew.
later tonight when I am able to post a pict of the fuse panel I will. I am concerned because the previous owner has 15s, 25, 20s, and 30s in place. A friend told me he thinks only 15s are supposed to be there however, I read online, a 25 should be in place as well to protect the converter? Like I said I don't know much about this. I just want to prevent a fire.
The last issue is that the fridge works real well on LP... but not on AC. I checked the power plug for power and there is power. I also checked the fuse connections and changed them just in case, heating element connection is also good on both ends, and it still won't cool down. The gfi in the bathroom was tripped and I just reset it and am trying again. If you have any other suggestions I would greatly appreciate it. Again, thank you so much for your help.
