Be sure to drain the (W/H) 1st,then the low point drains! If you do it in reverse the flow carries (Crud) from the W/H downstream in the lines! Youroo!!
And don't forget to turn off the Electric before you drain!
__________________ There's no use crying over spilt milk... unless it's on your keyboard.
