Old 05-11-2023, 04:03 AM   #1
Outside water heater rocker switch
Hello,
Im fairly new to the RV life, recently my water heater died, turns out it was just the switch outside that was no good, the plumber removed the switch, and was ordering a new one, but I can’t get ahold of him now, so im gonna fix it myself, but he took the old switch, so I don’t know the voltage etc needed, does any know will any rocker switch work on this, the two Leeds are just sitting there, but I don’t want to put in the wrong one and cause an issue or fire or anything.
Any suggestions?
Dr5356 is offline   Reply With Quote
Old 05-11-2023, 05:55 AM   #2
njfishing's Avatar
I’d google your make and model hot water heater, find the part number in the parts diagram and go to Amazon search on that part number and see if they have it. I had to order a heating element for mine, did the same and had it in 2 days.
That was also the case when I had to order a control board for my RV fridge.
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
njfishing is offline   Reply With Quote
Old 05-11-2023, 06:50 AM   #3
What you need is a Mini Rocker Switch, SPST, On/Off. Measure the mounting hole, it should be about ½" wide and 1" long (.470" x 1.026). Find one that fits that size mounting hole and is rated for 15 amps or greater at 125 volts and it will work.
Here's one that would work, but I'm sure you can find others. Carling Rocker Switch
Gotta go campin!
Old 05-11-2023, 07:07 AM   #4
Suburban # 232259
Here's one on Amazon but they can be found elsewhere too.
Suburban Rocker Switch
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
heater, switch, water, water heater
