Originally Posted by alush71
Would they be inside the camper? I do not see them outside.
If you haven’t seen them then it is not likely you turned them. You may not have them but usually they are in the driver’s side basement.
Does the motor keep running but the slide does not retract? Does the motor bog down? Have you checked the fluid level?
The fluid reservoir will e where the motor located. Have someone press the button and listen for and find the motor. Again, usually in the basement. Maybe someone with the same RV will chime in...
