02-17-2011, 10:32 PM
stabilization systems
Do any of the aftermarket stabilization systems (such as JT or steady fast) help to reduce movement inside my 5th wheel. I have a pin tipod and a set of tire jacks, both of which help, but still need help. My unit is a 345RET. thanks
02-18-2011, 12:18 PM
Get the steady fast
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
02-18-2011, 01:14 PM
Thanks for your quick reply. In your opinion, will a steady fast system make a noticeable difference?
02-18-2011, 05:13 PM
camping
Iggy did a thread on the steady fast, try this link:
http://www.forestriverforums.com/for...tem-10344.html
if it wont work look in tech talk- mods and upgrades.
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
02-20-2011, 10:03 PM
Plug It Right
We've been using our Plug It Right stabilizers for over 5 years and are completely happy with them. No more interior movement when someone is walking or when the washer is on spin cycle. Once installed you never have to remove them, they just follow whatever your jacks do. Diana
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.
02-21-2011, 11:20 AM
Thanks Dutch and Di. I am going to some system or another, just haven't decided which. We have gone to 2 RV shows of late, and most who have anything, like their Steady Fast, for the ease of setup! I haven't decided.
Our unit is 38'11",triple slide, and I feel vibration on both ends. I have also had several people suggest jacks in the area of the axles, which apparently take the spring out of the suspension. Thanks again.
04-01-2012, 03:33 AM
Put an extra set of crank down jacks in front of the front axle. I have a 2011 355QBQ and had the same problem. No issues at all now since I installed the extra jacks, I also use the king pin stabilizer. Hope this helps..... A cheap solution to your problem.
04-01-2012, 07:24 AM
We have the JT Strongarm stabilizers, they really knock down the movement. Not a 100% elimination, but a 90+% reduction.
I am able to get up in the morning and walk around without waking the wife due to movement.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
04-01-2012, 07:32 AM
We had a fifth wheel pin tripod, and it worked well, but I got tired of tripping over it. So I made my own 'steadyfast" system for the front legs, and it works 100%. But there was still a bit of wiggle at the back. I have bought X-chocks for the wheels and will try that this year. If still not perfect, will add a "steadyfast" bar to the back jacks.
I really don't like motion in the camper, so will do whatever it takes to eliminate it completely.
04-01-2012, 08:31 AM
That is our experience as well, small movement in the rear, front is rock solid. I am going to order two additional arms for the rear, so we have a four lock at the rear as well.
04-01-2012, 08:52 AM
We did the same thing, installing a set 30" jacks in front of the axles and it made a world of a difference. We even have the screw jacks under the slider. With the two sets of the sissor jacks, the slider jacks and the king pin stabilizer, the tire pounce gone.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
04-01-2012, 09:06 AM
04-20-2012, 05:32 PM
steady Fast has made our trailer rock solid..
04-20-2012, 06:13 PM
I use the Winfield cross brace system and it works GR8!
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-20-2012, 06:26 PM
X2 With the BAL X-Chocks
2012 Stealth RG3210
2011 Dodge Ram 2500 Mega Cab Laramie 4x4
2010 Ford F150 Super Crew Lariat 4x4
04-20-2012, 06:32 PM
X2
Bill
2009 Flagstaff 8528 RKSS
2019 GMC 2500 HD Diesel
Pullrite Superglide 14K
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
