Originally Posted by Craig Blaske
I have a trailer to tow. The trailer is already wired for stop light and blinkers. I need to wire a female plug to the camper lights to connect the two.
You would need a 4 pole knock out wiring harness and a few quick splicers.
brown wires work the running light circuit
yellow works left stop/turn signal
green works the right stop/turn signal
white works the ground circuit of the trailer.
This will give you all of the taillight signals on a 4-way that you would need for your small utility trailer to plug into and function properly
https://duckduckgo.com/?q=4+pole+kno...romentp&ia=web
you would pick your wires up somewhere in the back, not knowing your unit I can not tell you exactly where.
