Old 03-03-2020, 10:01 AM   #1
Front Cap Short bed Friendly?
Hey everyone, so I have had my eye on the 384QBOK for some time now. We are preparing to order a new build in the next few weeks. I have a short bed 6.5" and was planning on using the andersen ultimate hitch. I really would prefer that over a slider or pull rite auto slider. Looking to see what you are all using and if the front cap is angled well to get a good turing radius while still missing the cab of the truck. If you have pictures that would be awesome too! I have looked at the sandpiper same floorplan, they are made in the same plant side by side with the sierra but they use a different front cap!?! The sandpipers look angled more. Anyway I am going with the sierra and looking for some real owners feedback.
cuttymcgavin is offline   Reply With Quote
Old 03-03-2020, 10:38 AM   #2
KSH
I have a Chaparral 295x with the angled nose, I forgot what it's called. No issues with Andersen and my short bed. Ram 2500.
KSH is offline   Reply With Quote
Old 03-03-2020, 12:54 PM   #3
LOL thanks KSH!! I actually just private messaged you!!
Old 03-04-2020, 04:14 PM   #4
We have a 2020 Sierra 379FLOK that I tow with a RAM 3500 SRW with a 6.5' box. I purchased the Pullrite auto sliding hitch to fit a RAM puck system in the box of the truck. Once I started towing I realized that I really probably didn't need to go with an auto slider hitch. The front end of the Sierra is well rounded and with it sits in the box of my truck I have the same clearance to my back window as I would if I had an 8' box. I think there is plenty of clearance for my rear truck window to clear the front nose of the camper (with the new nose design. I bought the auto sliding hitch basically as a "better safe than sorry" precaution from what everybody told me in the past about pulling a 5th wheel camper with a 6.5' box. When my friend, who has an 8' box, pulled our Sierra we measured the distance from the hitch placement to the back window of his truck and compared it to mine, I thought the distances were the same. The difference in the trucks must be at the end of the box.
ChadsSierraNEWI is offline   Reply With Quote
Old 03-04-2020, 04:20 PM   #5
Hey Chad! Congrats on the New Sierra!! Thank you for your feedback! I was also thinking about getting the pullrite auto slide hitch but I am looking for a light hitch, hence the andersen. Good luck with the new unit!! If you ever get a chance post me some pics of your setup and it all hooked up!
Old 03-04-2020, 04:23 PM   #6
I've never towed with anything else, but I love my Reese Revolution ("sidewinder"). I haven't tried, but I believe I'd have to go past 90 degrees before I could make contact with the back of the cab on my Ram 2500 short bed.
2012 Ram Laramie 2500 4x4 CC SB Cummins
2016 Flagstaff 8528RKWS
Patrick (order taker), Barbara (order giver) & Jasper (Dutch Shepherd) and now Jade (Boxer/Lab/Pointer hybrid) aka PB&JJ
PatrickY is offline   Reply With Quote
Old 03-04-2020, 04:29 PM   #7
Yeah I was planning on using the sidewinder as my pin box but The new sierras have a new pin box called the rhino box and it is not compatible with the sidewinder at this time. Definitely a great product from what I have read and seen!!
Old 03-04-2020, 04:30 PM   #8
It might be a little while before I can get pics for you. I didn't take any last fall and there is currently a foot of snow that is sitting in front of my trailer, where I would hook the truck up. I'll try to get you some this spring when I get things moving/going for the 2020 spring.
From what I read, the Pullrites are 150 or so if you get them in the smaller sizes and/or without the OE puck system base. Because they only make one size for the RAMs, I had to get a 24K sized hitch. It takes to good sized guys to move it in and out of the truck. Once I installed it last summer, it stayed in my truck till I was done camping for the year. Hopefully I will be reinstalling it again soon for the 2020 season. I am thinking of installing an electric ceiling hoist/lift in my garage, above where the box of my truck sits, to help lift the hitch out of my truck by myself. My friend has one in his garage and it works great for that purpose.
Chad
- 2020 Sierra 379FLOK
- 2014 RAM 3500 SRW Cummins 6.7L
- Pullrite 24K OE SuperGlide for RAM (puck system)
Old 03-05-2020, 02:20 PM   #9
I have a Ram 2500 short box 4x4 with a B&W hitch set back in the box with a standard mount pulled a2014 Rockwood signature 8181SS then a 2018 Wildcat 32WB and now a 2020 Rockwood signature 2898KS I could jackknife all three with no cab strike.
Skiveywaver3 is offline   Reply With Quote
Old 03-06-2020, 11:40 AM   #10
KSH
I assume at 150lbs you don't have the pull rite super lite correct? My super lite is about 50lbs.
Old 03-06-2020, 11:48 AM   #11
I tow with an older Chevy Duramax short box. Old trailer was a flat nosed Montana and had to use the roll back hitch all of the time to back into a tight space. Bought a new (2017) Crusader and have shimmed my old school roll back to stop it from clunking and creaking. I never need it now, and do a 90 degree cut without issue. I, like many others, had considered the fancier hitches that move back as you turn, but it just wasn't needed after the new trailer purchase.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
Comanchecreek is offline   Reply With Quote
Old 03-07-2020, 09:39 AM   #12
DouglasReid's Avatar
I was just reading about that design change. The Rhino Box is a pin box that does not swivel like the Reese Sidewinder or Revolution.
Im not sure where you got your information about compatibility but Lippert and Reese would be the definitive sources for whether or not the Reese Sidewinder could be used on that new Lippert frame design.
Here is some contact info for Lippert from the article on the frame design change
Lippert Components, Inc.
3501 County Road 6 East
Elkhart, IN 46514
Email: marcom@lci1.com
And here is the article itself for anyone interested.
https://www.lci1.com/forest-river-ad...20-model-units
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-07-2020, 11:40 AM   #13
KSH
Adapter for pull rite
https://www.pullrite.com/331723
Old 03-07-2020, 11:45 AM   #14
KSH
Cutty,
Try this conversion. They said they guarantee it will work with the rambox.
https://genyhitch.com/product/execut...-torsion-flex/
Nothing needed in the bed but the ball.
Old 03-08-2020, 04:50 PM   #15
I meant that I've read that the Pullrite OE hitches rated for 16000 lbs are about 150lbs in weight. My Pullrite OE hitch, for my RAM truck, which is rated for 24,000 lbs weighs about 250 to 300 lbs (with the heavy duty base on it). I wished my hitch was a little lighter so I could move it myself. It is what it is but I like how it handles with my new 42' Sierra.
Chad
Old 03-08-2020, 04:56 PM   #16
Elkhart, IN 46514
I have the new Rhino Box pin box on my new Sierra 2020 5th wheel. Because Pullrite didn't make a catch plate for the Rhino Box when I went to take delivery of my new 5th wheel, I tried switching out the Rhino Box with a Lippert Roto Flex head. I thought it would be no problem because they both are made by Lippert. Wrong! The one minor difference is that on the Rhino Box, the bolt holes are a 1/2" different than the previous Lippert Pin Boxes. I think this is the reason why that if the trailer has Rhino Box pin box, that no other style of pin box will work with it. It was a crappy thing of Lippert to do, but if your new trailer comes with a Rhino Box pin box, good luck in finding another pin box to fit the Rhino Box bracket bolt holes.
Chad
Old 03-10-2020, 03:19 PM   #17
That is correct Chad,
I did receive the info from Reese directly as well as Lippert directly that there is no other pin box currently to replace the Rhino box. I even reached out to Moryde and they do not either. I am sure over time they will, but for us folks who want that particular fifth wheel now, we are limited!! Chad do you have the ramboxes on your truck. The Lippert engineer believes that I could use the superglide with that rhino box and still have clearance when it slides all the way back!? I dont picture that working! LOL!
KSH thank you for that link, I have looked into that company before, I will check it out again!!
Old 03-11-2020, 08:29 AM   #18
I don't have the RAM Box on my truck. I have the standard 6'4" box on my truck with the tow package, which includes the pucks in the base of the box. Sorry I don't have any pics of how the camper/hitch sits on my truck when connected. I won't be able to get you pics for a few weeks as there is still snow in my way to hook up the camper to the truck and plus my hitch is still in storage. I can tell you that with the Pullrite SuperGlide hitch in my truck bed, it does sit high enough that my Sierra 5th wheel sits a good 6 to 8 inches above the top of the box walls on the truck. When the camper is connected to the hitch in my truck, I am still able to get my head and arm/shoulder in the space between the top of the wall of the box of the truck and the underside of the camper. If you're worried about the height between the camper and the top of the bed box wall, Pullrite also sells a high profile foot kit that will raise the hitch up another 1-1/2" and a 3" lift kit for the traditional rail bases. If you have any questions about using the Pullrite SuperGlide hitch with your RAM truck with the RAM Box, contact Pullrite directly and they will answer your questions. I had to go to them about getting my capture plate (that was still in prototype testing yet) so that I could tow my new camper last September. From what I have heard from other RAM owners, the reason why RAM doesn't recommend towing a 5th wheel with the RAM Box is because you can not open the storage box lid/top to be open 100%. I have seen pics (on another forum) of a Ram truck with the RAM Box towing a 5th wheel so it is possible. Hopefully this helps you out.
Chad
Old 03-11-2020, 08:56 AM   #19
If you have any other questions, I found these other forum articles to help:
https://www.ramforumz.com/threads/to...rambox.239230/
https://www.ramforumz.com/threads/ne...-hookup.232661
Chad
Old 03-11-2020, 09:18 AM   #20
KSH
I can open my ram boxes just find. No issue with both the Andersen ultimate or the pull rite super lite.
bed
