Originally Posted by sjschmidtkazoo1977
I own a Sierra 378FB. Two items, please: 1) There is a valve located in my water service area and I don't know what it is for. It's located on the bottom, right side of the water service area. Any ideas? Should that valve be open or closed when I winterize my unit? 2) How do I replace the red plastic latches on my emergency egress windows that have broken? Any assistance will be greatly appreciated. Thanks!
I see this is your 1st post, welcome!
Every R/V is plumbed and set up differently and as such, not all R/Vs have the same thing(s) even across like models.
As mentioned, a photo of the valve you are referring to would help immensely, otherwise we are just guessing.
I have never seen the red plastic tabs on the exit windows offered separately.
There are certainly generic tabs that could be used,
Something like this...
