Originally Posted by csterl01
On the backside of your panel is a logic module that controls the LED's.
Connector:
Red wire 12V
White wire ground
Blue wire FW tank
Brown wire black tank
Gray wire gray tank
Normally, the 12V wire is piggybacked off one of the switches in the panel.
Same for the ground wire.
Each tank has a 12V wire (from the module), 3 sensor wires and a ground wire
Hope this helps you some.
