I'd also add that I don't think gen prep packages were common if at all available in the Sandpiper/Sierra line. I don't think it would be a difficult retrofit, just be sure of the dimensions of the generator and where you wish to install it. You may also want to check out the battery bay. Depending on the number of batteries you wish to install, you may need to make a retrofit there as well. Many of the later models came with residential fridges which will put a higher demand when your off grid. You can likely install everything you want, but it will require some work.
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
