08-01-2021, 12:53 PM
Slideout stop and start
My Sierra 355QBQ (2010) has one switch to operate 4 slides. The biggest slide goes out last and usually the last to come in. Recently, it has been stopping and needing a few minutes to start moving again. A few weeks ago, it wouldn't go out. I waited a few minutes and then it did. Fluid level looks ok. I could maybe add some but have been reading about reset breakers needing to be replaced. I am not sure where these are. Anyone else have a similar problem? How would I match these up to new ones?
08-01-2021, 11:02 PM
Now a "Top Member"
So let me ask you a question. When the slide is coming in, do you hear a "click" just before it stops? If not, listen for it. It should be in the battery compartment area. It is very likely it is a fuse/switch. See my picture. Your problem sounds exactly like what mine did. Come in for a few seconds, "click", stop, wait a few seconds, come in some more, "click", stop, wait, until it was all the way in. It took me a bit to trace down that fuse, or switch, or whatever it's called, but I replaced it, and no more problems. I would start there.
Good luck, and keep us posted.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
08-02-2021, 05:23 AM
Frog-Toberfest Organizer
My slides have done this since the day I bought it new. I wondered if there was a problem. I too will look for this relay fuse and listen to see if it's what's causing the issue.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=47 '20=47 '21=64 '22=62 '23=72 '24=0
08-02-2021, 06:14 AM
Attachment 260221
That is an automatic resetting circuit breaker. As the load on it builds, it trips then resets itself when it has cooled off.
2018 Georgetown XL 377TS
2020 Jeep Gladiator "Toad"
CAMPING (n. CAM-ping) - When you walk the dog in your pajamas with a cup of coffee in one hand and a bag of dog poop in the other while striking up a conversation with total strangers.
08-02-2021, 09:00 AM
Not sure WRT your unit, but those are usually replaced with an 80a breaker in Keystone Montanas. There's a Lippert bulletin available on their site.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
08-02-2021, 09:28 AM
Since you have hydraulic slides and not electric, does the pump motor continue to run when the slide seems to stop? If the pump continues to run, then you don't have an electrical issue. The slides work on the principle of whichever slide takes the least effort (pressure) to move, that's the slide that moves first and then on to the next until they are all in/out.
The hydraulic pump/actuator does have some override valves on it if you want to move a specific slide. Have any of them been recently adjusted/changed? Are you regularly maintaining the slide mechanism (rack) and seals?
08-02-2021, 11:43 AM
The motor has not continued to run. Except for this last time. It stopped moving and had the sound of it running but no movement. I released the switch and waited a short time and then it continued to work moving the slide out. I spray down the gear rack underneath with a dry lube and regularly inspect everything.
08-02-2021, 12:01 PM
Attachment 260221
X2 I had same issue on my Sandpiper 5th wheel since unit was new. Troubleshot and once I replaced the Relay/Fuse problem was history.
Christian M
2021 Forest River Forester 3011DS
08-02-2021, 01:08 PM
Yes, I am going to check this out. Thank you and Ed.Junior
08-02-2021, 01:20 PM
I think with 4 slides the breaker will heat up but it will reset. We have 3 slides(2 huge) and it still does it after replacing the breaker. It will automatically reset in just a few seconds
08-02-2021, 01:37 PM
Where were your reset breakers at
08-02-2021, 01:39 PM
Attachment 260221
Are these a specific amperage? I've read 20 amp, 40 amp. Then 30 amp and even 80 amp
08-02-2021, 01:48 PM
Mine are in the front compartment on the left behind a plastic sheet. You should see a couple of brass bus bars and they are attached to them. The slides ran off the one furthest from the door I believe I should be by the camper in a couple of days and send pic. Let me know
08-02-2021, 02:24 PM
Had the same problem and same fix as EdJunior was saying. Very frustrating to deal with as the switch needed time to recover. Start/Stop/Start/Stop.. it was driving me crazy. Glad it got fixed! It has stayed fixed for ~ 8 years now. Each time the slides cycle in or out it has been in one continuous cycle for all four slides.
2019 Ford F-350 6.7 Diesel
2013 Sierra 365saq
FLY NAVY
09-05-2022, 09:05 PM
UPDATE : I finally got around to finding the breakers. I ordered two from Amazon and installed them this past weekend. Ran the slides in and out several times with no issues. Simple fix. Thanks for all of the responses and advice.
09-05-2022, 10:03 PM
Now a "Top Member"
Originally Posted by OKI Marine
UPDATE : I finally got around to finding the breakers. I ordered two from Amazon and installed them this past weekend. Ran the slides in and out several times with no issues. Simple fix. Thanks for all of the responses and advice. Attachment 278828
Awesome man. Thanks for reporting back with the update. Glad we were able to get you fixed up.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
