Old 03-10-2020, 05:52 PM   #1
31qbh tire size
It came with 225/75 15’s has anyone changed over to 255/65 16’s? I ask because I can get these in e rated for an extreme deal. Can it fit has anyone tried?
2005 Wildcat 31QSB
2005 Silverado 3500 ECSB Diesel
flynn78us is offline   Reply With Quote
Old 03-10-2020, 06:01 PM   #2
rsdata's Avatar
using this below I find
https://tiresize.com/calculator/
15 inch tires/wheels are 28.3 inches in diameter
16 inch tires/wheels are 29.1 inches diameter
now need measurements from trailer axles... remember to account for spring bounce at the top of the tires on the trailer
“Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 03-10-2020, 06:07 PM   #3
I was using a calculator also and found the overall. I haven’t had the camper down the road other then when I bought it out of Rhode Island. My thoughts are as long as the distance from top of tire to closest interference doesn’t change between the 2 to much it should be good correct. I love the idea of going from d rated to e.
2005 Wildcat 31QSB
Old 03-10-2020, 06:11 PM   #4
rsdata's Avatar
the tires may be cheap but also account for needing new 16 inch wheels to mount the tires on, X 5 including the spare you can certainly find 15 inch tires in e rating
2014 Shamrock 183
Old 03-10-2020, 06:20 PM   #5
D W
D W's Avatar
If you got a good deal, and you have the room, go for it. Of course that will entail 5 tires, and five 16" wheels.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 03-10-2020, 06:32 PM   #6
It’s a set of 5 wheels and tires. I know I can get 15” e rated that’s what is on my enclosed trailer. Deal is so good I’ll be getting them and putting them on that or the camper. Both need tires but I’d like the best sent in the camper. And put the camper tires on the enclosed trailer. Either way something’s getting new 16” tires and wheels
2005 Wildcat 31QSB
Old 03-10-2020, 06:37 PM   #7
DW is your 04 a duramax? If so is it an lly
2005 Wildcat 31QSB
Old 03-10-2020, 07:21 PM   #8
D W
D W's Avatar
No sir. It's a 6.2L Vortec (LS3) gasser.
2016 Salem 27RKSS
tire
