08-21-2014, 10:12 PM
#841
Originally Posted by gljurczyk
Herk, I just love your library. You have something on everything you should be a rep....
Just trying to keep the shiny side up!
HAM CALLSIGN - KC3FFW
08-22-2014, 09:23 AM
#842
Glenn,
When i was talking to Herk at Goshen, I made mention I would like to get a copy of his library.
He said sure, just send me a portable 3 TERABYTE  drive and I can copy it for you
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
08-22-2014, 09:25 AM
#843
Speaking of which Herk, after a "small incident" on the way back from Goshen...what Brand/Model of Dash Camera do you use?
08-22-2014, 04:36 PM
#844
Bought two "cheapies" at last year's rally and one failed. I replaced it at this year's rally with the f20 double camera car camcorder. Seems to work great with one wide angle "steerable" and one tight zoom "steerable" cameras.
CAR CAMCORDER F20 | eBay
NOT MY CAMERA! TURN OFF AUDIO on the first video
08-22-2014, 04:37 PM
#845
Glenn,
Oh, I miss understood. I thought you wanted my "entertainment" library and not the Herkbrary. The Herkbrary sits right at 160 gigabytes right now.
08-26-2014, 02:10 PM
#846
Wildcat 337fb living room slide does not close properly. When I close the living room slide the whole thing closes right until half way. Then the top seemingly gets stuck (yes, I checked the roof and interior). It will look crooked and the floor inside lifts up on an angle. I then slide it back out about a foot or so and back in. So far that works, but is that a problem I should be concerned about?
08-26-2014, 04:24 PM
#847
Where you level when this happened? If yes then I would get it checked out.
Coachmen M/H
Concord
2018 / 300 DSC
08-26-2014, 04:27 PM
#848
Yes. I was level both times it happened. Both were leaving campgrounds, and I use a 4 foot level when I setup camp.
08-26-2014, 04:34 PM
#849
It looks like your still in warranty? Take it in you have to had to come out of adjustment. What kinda of slide is it, electric or hydraulic? There are some good u-tube under lippert slides take a look at them. That is not Normal what you have described. You might be able lay under it and have someone bring it in and see if you are seeing anything binding. Good Luck
Coachmen M/H
Concord
2018 / 300 DSC
09-01-2014, 07:21 PM
#850
plan
J aimerai savoir si c est possible d avoir le plan électrique et l emplacement des réservoirs d eau pour wildcat 282 rkx 2014
Je reside au Quebec
P.s. quelque petite chose a améliorée ,les 2 table de chevet sont trop large avec les drap et la douillete est trop serrée . La porte coulissante pourrait être plus haute de 3 pouce pour cacher plus de lumière du dome de la douche. La prise d air du plancher près de la porte arrive en dessous du fauteuil.
Merci de prendre du temps pour me lire
09-01-2014, 07:30 PM
#851
Plain Old Member
First time I've seen a post in French.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
09-02-2014, 04:12 AM
#852
Je reside au Quebec
let me get this translated first....
Coachmen M/H
Concord
2018 / 300 DSC
09-02-2014, 07:16 AM
#853
JAYCO Representative
Please send me a private message with all pertinent details including your full contact information (name, phone and email), Wildcat VIN#, and the dealership you purchased from.
09-02-2014, 07:29 AM
#854
Je reside au Quebec
I'm going to have to use Google's translation for this!
I'd like to know if is possible to have electrical and location of water tanks for a 2014 Wildcat 282RKX. I reside in Quebec.
P.S. Something small to be improved, the 2 bedside tables are too wide and with bedding it's too tight. The sliding door could be higher than 3 inches to hide the dome light over the shower. The air intake of the floor near the door reaches below the chair. Thank you for taking time to read me.
This may be easier if you get your Wildcat dealership involved.
I do not have an electrical schematic available at this time.
On a 2014 Wildcat 282RKX, the water tank locations are as follows:
1. The 50 gallon fresh water tank is behind the rear axle.
2. One 50 gallon gray water tank is located in the rear under the kitchen.
3. The other 50 gallon gray water tank is located centrally under the bathroom.
4. The 50 gallon black water tank is located directly under the bathroom.
I hope this helps! Please use your local Wildcat dealer in Quebec for more assistance!
AND IN FRENCH (PER GOOGLE'S TRANSLATION) WITH APOLOGIES:
Cela peut être plus facile si vous obtenez votre concessionnaire Wildcat impliqué.
Je n'ai pas un schéma électrique disponible en ce moment.
Sur un 2014 Wildcat 282RKX, les emplacements des réservoirs d'eau sont les suivantes:
1. Le réservoir d'eau douce de 50 gallons est derrière l'essieu arrière.
2. Un réservoir de 50 gallons d'eau grise est située à l'arrière sous la cuisine.
3. L'autre réservoir d'eau grise de 50 gallons est situé dans la salle de bains.
4. Le réservoir d'eau noire de 50 gallons est situé directement sous la salle de bains.
J'espère que cela aide! S'il vous plaît utilisez votre revendeur Wildcat locale au Québec depuis plus de l'aide!
09-02-2014, 09:47 AM
#855
Originally Posted by jlmarta
Well, to answer your question, it's pretty standard that load range D tires require 65 PSI and the E's require 80PSI. If you'll re-read my original post I think you'll see that I have a kinda catch-22 situation going here. If I don't follow the requirements of the TPMS manufacturer my warranty with them will be no good. And on order to follow their requirements I need for Forest River to agree that 80PSI is what I need to have in E tires. I'm confident that they know at least that much about tires.
And, in answer to Crocus, after the experiences I've had and the battles I've lost regarding warranties on tires, there's no way I'll knowingly run those tires under-inflated. As I said earlier, the manufacturers all seem to use the same excuse, regardless of circumstances, because they know there's no way you can prove you weren't running them under-inflated.
Many thanks to both of you for your input. It's appreciated.
I have a 32RL Sterling, was coming home yesterday and had a blow out, had set my tire pressure at 75 psi before i left on the trip, tire stamping and FR says 80 psi. It was pretty bad and did some damage to my unit..this is what upset me the most. Has anyone had the same problem also is 75 psi to high, I do not want this to happen again.
09-02-2014, 05:25 PM
#856
Fading paint on 2013
Hello, I have a 2013 344QB with the grey cap. It is fading to white really bad on top. The unit is only 18 months old. I have been reading this is happening often. I know there is a year warranty on the camper, but 18 months for the paint to go bad is pretty bad. Will Wildcat re-paint this? It is a very common problem now.
 2013 Ford F-350, FX4 ,Long Bed, 6.7 Diesel, 11500# GVW package, camper package, plow package, Electronic locking 3.73 rear end.
Husky 16K slider hitch.
New Trailer 2013 Wildcat 344QB Touring Edition with angled master bed.
09-02-2014, 05:33 PM
#857
Toy-aholic
Looks like an epidemic.... I invite you to read a thread I started on the very same issue.....Forest River products...click below
http://www.forestriverforums.com/for...per-66552.html
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
09-02-2014, 05:46 PM
#858
09-02-2014, 09:27 PM
#859
Hey cheap Tonka toy? I have my very first Tonka dump truck from the late 50's early 60's. That this is built better than any RV I have seen out there. It's has been dropped, banged up and beaten to death and the paint is still looking like new. No dents or bends. Americans made great stuff back then. They can make a cheap Chevrolet Volt just from the metal from that truck.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
09-03-2014, 12:24 AM
#860
This is a warranty repair, I purchased a new 2012 32 RL Wildcat Sterling last October and had the same issue. They repainted the entire front cap and never gave me any problems about it.
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat  |
