09-03-2014, 07:29 AM
#861
Originally Posted by GaryJCoz
Wildcat 337fb living room slide does not close properly. When I close the living room slide the whole thing closes right until half way. Then the top seemingly gets stuck (yes, I checked the roof and interior). It will look crooked and the floor inside lifts up on an angle. I then slide it back out about a foot or so and back in. So far that works, but is that a problem I should be concerned about?
We have the same issue with our 295RSX and would be interested in any information/recommendations you have.
G.
2015 FR Wildcat 295RSX
F250 Diesel
PullRite 18K
09-03-2014, 08:01 AM
#862
G.
Apparently, several Wildcat slide-outs have a design and/or installation problems. The kitchen/entertainment center slide on our 295RSX was adjusted multiple times (the dealership service technician finally discovered/invented a correction which worked). Our slide dropped down on its way out and cut the flooring plus it disassembled the wood trim at its bottom left before it was corrected. This same technician showed me another 295RSX on the lot yesterday with the same issue from the factory. Another 295RSX was sold and returned to the dealership with the same problem.
09-03-2014, 09:33 AM
#863
JAYCO Representative
Originally Posted by Greenshield
Hello, I have a 2013 344QB with the grey cap. It is fading to white really bad on top. The unit is only 18 months old. I have been reading this is happening often. I know there is a year warranty on the camper, but 18 months for the paint to go bad is pretty bad. Will Wildcat re-paint this? It is a very common problem now.
Please send me a private message with your contact information (name, phone, email), complete VIN#, and the name of your local Wildcat dealer. I'll forward this on to our service team for more discussion.
For the record, Wildcat has used multiple custom colored gel-coated caps since 2011. While some customers have experienced issues with fading or what is sometimes called "chalking," this is not the norm (your results may vary based on usage, care, environment, and geography). Our cap supplier worked closely with us to pick balanced colors that wouldn't cause problems and specified a high quality, UV protected gel for production.
During our most recent production, the cap color was a darker gray and cap surface area was larger, so we did start painting with an automotive paint (vs. using a color infused gel-coat).
The newest Wildcat units coming offline are also being painted to get EXACTLY the color we wanted and to have a high metallic content. While this process is much more expensive, I believe it makes the coach look great and will end up easier to maintain over time.
09-03-2014, 09:59 AM
#864
Pin box bolt torque
Chris, (or others),
Do you have the specs on the proper torque for the bolts on the pin box on a 2015 312QBX (BAL drop frame)? I would like to move my pin up one set of holes to level out the trailer better while towing, and want to get the bolts torqued properly...
Thanks,
--Paul
09-03-2014, 10:54 AM
#865
Originally Posted by pbryan
Chris, (or others),
Thanks,
--Paul
I will contact BAL and see what information I can get on this!
09-03-2014, 11:31 AM
#866
Chris, (or others),
Thanks,
--Paul
This is directly from BAL's engineering:
The bolts should be torqued to 130 ft*lbs.
09-03-2014, 02:07 PM
#867
Thanks!
09-03-2014, 09:34 PM
#868
Now that's quick service.
Chuck and Joanne
2014 Flagstaff Super Lite Classic 27RLWS Emerald
2013 Dodge 2500 4x4 Laramie Crew
Equal-i-zer 1200/12,000 4-point WDH
09-05-2014, 05:38 PM
#869
I'm looking for a replacement part for the slide on my fifth wheel. It's the bottom left corner of the dinette slide out. What information do you need to identify this part.
09-13-2014, 04:45 PM
#870
Just picked up my 2015 295rsx and besides a bunch
of quality control issues my awning does not work, I noticed the 20 amp fuse is blown. Changed it and tried it again and there's an audible pop when it blows so I'm assuming the factory or the dealer ignored the problem. After trouble shooting it I'm convinced that the white/red cable that hooks up to the upper prong of the switch has a short. Is there a wiring diagram or can you tell me where that wire goes? I still can't believe that these units leave the factory with trim that are not attached straight and a warped aisle bathroom door, reclining tv chairs that one feels like it's missing all it's padding and the other one has too much. This is obvious stuff, I came off a Kodiak TT that spent a total of 4 months getting things repaired, I was hoping this would not be the case with this unit and I'm hoping the dealer can resolve these items quickly.
09-14-2014, 06:42 AM
#871
Good luck with that.
F250 Diesel
PullRite 18K
09-15-2014, 08:37 AM
#872
GLCM Warrior
Hi Chris,
I have a few questions regarding the front landing gear on a 2014 Wildcat 312QBX...which, per the Forest River website, I surmise is a Lippert brand landing gear.
Do you know if it is in fact a Lippert component?
The landing gear on our Wildcat has two grease zerks at the top of each leg, so it begs the question...does the landing gear require lubrication at these zerks? The dealer made no mention of any maintenance requirements for the landing gear and no manual was provided in the literature supplied with the trailer.
If it does require lubrication, any idea what type of grease is specified?
I tried finding some answers on the Lippert website...but to no avail.
Thanks,
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
09-15-2014, 09:37 AM
#873
Tank Sizes??
CHRIS....
I have a 2007 Wildcat 30RLBS West Coast Edition 5th Wheel (new to me 1 month plus).
In the 30RLBS Wildcat information brochure the tank sizes are stated as:
Fresh 43 gal
Black 37 gal
Gray 37 gal
As my unit has 2 gray tanks are they 37 gal "each" or ?
Yes, there are 2 gray water dump valves and 1 black.
Kitchen sink is one, the bath sink and shower is the other.
Thanks for your help
-Islander-
Vancouver Island B.C.
'07 WildCat 30 RLBS ~ West Coast Edition ~ Trail Air - Tri Glide Pin Box 2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles Edge programmer, 4" SS exhaust turbo/back, Tru-Cool Max Trans Cooler, Bilstein Shocks Vancouver Island, B.C., Canada
09-15-2014, 01:45 PM
#874
Originally Posted by Islander
CHRIS....
Fresh 43 gal
Black 37 gal
Gray 37 gal
-Islander-
I would say combined.
Coachmen M/H
Concord
2018 / 300 DSC
09-15-2014, 07:24 PM
#875
If the zerks are there then I would give them a spot of grease. Don't be surprised the dealer had no idea. I find they don't know quite a lot about what they sell.
Chuck and Joanne
09-15-2014, 11:09 PM
#876
Jeffco, MO
New models for 2015/6
Any schedule when the new models will be published?
Mary & Ted
2016 Silverback 33IK
2015 GMC Sierra 2500HD CrewCab Diesel/Super Glide Hitch
Days camped 09 -53, 10 -56, 11 -57, 12 - 55, 13 - 46, 14 - 50, 15 - 60, 16 -32
7 FROG Rallies (Goshen(4), Charleston, Amana(2))
09-16-2014, 04:01 AM
#877
Hey Chris, I am trying to track down where is the best place to get a day/night shade for my window by my booth table on my fifth wheel camper?? My kids have wrecked the blind and I would like to replace it. I was told that the blinds are cheap but the issue is shipping to Canada is not? Can you tell me where or best way to get a day/night shade to me in Alberta, Canada here. Thanks
Tow Vehical 2012 Dodge Ram 3500 Mega cab Longhorn SRW. White and Chromed out!!!!
Wife's ride 2008 Chev Tahoe, 22x10 Deep dish triple dipped chrome and black rims, Blacked out ride!!!!
2012 Wildcat 323QB
09-16-2014, 09:57 PM
#878
GLCM Warrior
Thanks! I absolutely agree and intend to add grease...just as soon as I can figure out the best type. Found a few sites that say to be sure to add grease that is compatible with the grease already in use...and some that say to use extreme or high pressure grease. If I knew they were a Lippert brand I could call them...but I can't find anything but a model number (ZYT150-2-12) for the motor on the landing gear.
2014 Wildcat 312QBX
09-20-2014, 10:25 AM
#879
Does Chris still answer questions on this Thread???
2012 Wildcat 323QB
09-20-2014, 10:40 AM
#880
Yes he does.
Sent from my iPad
241rlx, 24rl, 252rlx, 25rl, 26bhs, 271rlx, 272rlx, 27rl, 27rls, 281rkx, 282rkx, 28rk, 28rkbs, 28rksb, 293rex, 295rsx, 297rlx, 29bhbp, 29bhs, 29fks, 29mk, 29rlbs, 302rl, 303bhx, 30bhs, 30loft, 30lsbs, 30rl, 311thx, 312bhx, 312bhx-ok, 312qbx, 313re, 313re-ok, 317rl, 31bh2b, 31bhs, 31qbh, 31thsb, 31ts, 327ck, 32qb, 32qbbs, 32qbt, 32rk, 32rl, 333mk, 337fb, 343fl, 344qb, 34flr, 34qb, 353ls, 35ls, alumacat, barrel roof, climatech, customer service, drop frame, extralite, factory, fifth wheel, forest river, laminated, led, led pad, nxg, parts, question, representative, service, sterling, sterling edition, tankless, touring edition, warranty, wildcat |
