Old 05-01-2017, 12:10 PM   #1
Atwood screen door latch
does anyone know where I can get an Atwood #10-15296A screen door latch. My dealer is of no help and I cant find anything on amazon or ebay. apparently they don't make this anymore.
2014 Wildcat 312BHX, 2003 Dodge Cummins
amoszer is offline   Reply With Quote
Old 05-01-2017, 01:47 PM   #2
That parts # turns up nothing. The left piece is all over the place. Nothing shows for the right-hand piece. Good luck. What brand and year did that come off of??
Old 05-01-2017, 02:12 PM   #3
Here is your fix. Permatex 84145 Permapoxy Black Plastic Weld - 0.84 fl. oz.
Old 05-01-2017, 02:48 PM   #4
its off of a 2014 wildcat.
Old 05-01-2017, 02:49 PM   #5
I found someone that re-pops the paddle part but I need the center piece that the paddle attaches to.
Old 05-02-2017, 12:08 PM   #6
camping world
Right Hand Screen Door Latch - RV Designer E285 - Screen Doors - Camping World
palmetto rogue is offline   Reply With Quote
Old 05-02-2017, 12:29 PM   #7
Atwood door latch
I have the same latch on my Mini Lite and it also broke. The Atwood latch was bought by Dometic and is no longer made. Any time I pass an RV Center I stop and ask if they have one (it would be old stock) and no one has so far. The one shown as a replacement won't work because there is a shaft that works the outside latch from the inside paddle (on the Atwood), you must have the complete set. If anyone finds a source for them I like to get one or two.
closecreek is offline   Reply With Quote
Old 05-02-2017, 12:51 PM   #8
Originally Posted by palmetto rogue View Post
Wrong part #. OP needs the paddle handle version.
Old 05-02-2017, 01:29 PM   #9
EBAY
panamabear is offline   Reply With Quote
Old 05-02-2017, 02:11 PM   #10
Originally Posted by panamabear View Post
EBAY
Nope. The Atwood handle is not in production. Ebay doesn't have any old ones.
Old 05-02-2017, 02:15 PM   #11
Scoundrel
HangDiver's Avatar
Look up forum user "RCCS". He graciously made some up out of aluminum and might have some left.
Rich J.
HangDiver is online now   Reply With Quote
Old 05-02-2017, 08:12 PM   #12
justpassinthru's Avatar
screen doir latch
Try adventurerv.net or etrailer.com . Accessories.lazydays.com and also walmart.com. I looked them up for you by google search rv screen door latches. Good luck
justpassinthru is offline   Reply With Quote
Old 05-02-2017, 09:43 PM   #13
CaptnJohn's Avatar
Try PPL. They are a great source for a lot of things and often lowest price as well.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 05-03-2017, 08:31 AM   #14
Ive searched ebay an amazon, contacted multiple dealers, went straight to forest river...nothing.
Old 05-03-2017, 08:34 AM   #15
DouglasReid's Avatar
If ALL else fails
If all else fails it is time to get a piece of scrap aluminum and break out the file, make one.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 05-03-2017, 09:26 AM   #16
Retired JSO's Avatar
I believe J R Products makes several ones and am sure a direct replacement for the Atwood latch is available . https://www.amazon.com/JR-Products-1.../dp/B00C88AA52.
I just Googled JR Products screen door latch and shop on google and over 25 door Products came up.
Also available at most RV part stores.
Retired JSO is offline   Reply With Quote
Old 05-03-2017, 09:39 AM   #17
Scoundrel
HangDiver's Avatar
The screen door handle the OP is looking for isn't made anymore, no one stocks them, and no company makes replacements. As mentioned in a previous post, only RCCS (on this forum) makes them. Send him a PM and see if he can help you.
http://www.forestriverforums.com/for...-115730-4.html
Old 05-03-2017, 10:38 AM   #18
RCCS only makes the interior paddle part. I ordered one from him but I need the outside handle as well. The outside handle is very unique - it has a hole in it that the interior paddle fits into so you can open the door from the inside without having to slide the screen over. The handles work in conjunction with eachother. Its not your typical replacement handle you can get anywhere. I've tried a bunch of those and they don't work in with the interior paddle like I need it to. I think Im going to have to do something custom. Thanks for input everyone!
Old 05-03-2017, 10:44 AM   #19
Scoundrel
HangDiver's Avatar
Thanks for clarifying. Let us know what you come up with.
Old 05-03-2017, 11:03 AM   #20
Member RCCS in this thread is making the paddle part out of aluminum and sent one for the cost of postage. He can help.
http://www.forestriverforums.com/for...le-115730.html
door
