Old 08-12-2022, 01:04 PM   #1
Chardagha's Avatar
Awning release
Gíday! I am having a recurring issue with my manual awning not wanting to release on the left side clip. I have lubed all parts in volved and occasionally it will release when I start to ull the awning down, but today, she doesnít want to release. I have tried gentle pressure with no luck today and I donít want to pry on anything.
This is an Ď04 Wildcat, but Iím sure it is not just a Wildcat issue. Any ideas? TIA
Chardagha is offline   Reply With Quote
Old 08-12-2022, 01:38 PM   #2
NMWildcat's Avatar
It is possible something is bent, but usually is caused by the awning material not rolling up straight. This is mostly caused by the material shifting position where it is attached to the tube which causes pressure when the arm moves into its stored position.
It has happened to me with manual and electric awnings. I determine which direction the material needs to move, lessen the tension on the material, and pull the material accordingly (using a ladder and sometimes a helper). Then when it rolls up straight, I put in a screw or two to hold the material in place.
Scott and Liz - Southern NM
awning
