Old 03-27-2016, 02:05 PM   #1
Axle ratings for 2016 Wildcat 275CKX?
Looking at a Wildcat 275CKX. Can anyone tell me what the axles are rated at for this unit? Also any common problems??
dbackerjim is offline   Reply With Quote
Old 03-27-2016, 02:20 PM   #2
Airdale's Avatar
Your trailer is required to have a federal certification label with that information. Look on the forward LH external section of your trailer for the label.
A Trailer Tire Poster
Airdale is offline   Reply With Quote
Old 03-28-2016, 08:00 AM   #3
Learjet's Avatar
should be 6,000 lbs axles
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 03-28-2016, 09:35 AM   #4
Better yet, look on the axle itself for the MFR decal with the rating. I have seen discrepancies between the federal cert and the axle label. Not suppose to happen, but this is the RV world.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 03-28-2016, 11:46 AM   #5
Airdale's Avatar
The axle manufacturers load capacities are not the official load capacity once they are fitted to an RV trailer.
Because the trailer manufacturer has the authority to set them to a GAWR.
The installed axle (s) may match-up with the trailer manufacturer's specs as built or reset to a lower value known as Gross Axle Weight Rating (GAWR).
The GAWR is the official value the trailer manufacturer uses to build the trailer around and is the value for tire and rim fitments.
Here is an example of a certification label with a GAWR set at 6750# for 7000# axles.
http://www.irv2.com/photopost/showfull.php?photo=22027
For all RV trailers the label above must be permanently attached to the LH forward external section of the trailer.
Old 03-28-2016, 01:58 PM   #6
Boots49's Avatar
Send a message via Skype™ to Boots49
Make sure you evenly distribute the weight in your RV. You can be under the GVWR & still be over the GAWR.
Al & Susanne
Aka: Puss 'n Boots
Wildcat 31 TS - Silverado 2500 DuraMax Diesel
Tip of the Day: Stay safe, have fun and never leave the cat out in the rain!
Boots49 is offline   Reply With Quote
Old 03-28-2016, 03:36 PM   #7
Blog: RVroadtripper.com
hbillsmith's Avatar
When I looked at several 2015 and 2016 Wildcat 295rsx units last year, it was peculiar that some units were 5000 axles and some were 6000. Same floor plans but the diff was that the 6000s had 16" wheels, others were 15" wheels.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
hbillsmith is offline   Reply With Quote
Old 03-28-2016, 06:46 PM   #8
Axle is rated for whatever you put into camper.
pdqparalegal1 is offline   Reply With Quote
axle, cat, wildcat
