Originally Posted by nayther
THAT'S IT! Finally got down on my hands and knees and found the switch, thanks all. Now if i can just figure out how they're feeding the tank heater power I'll be happy. I want to pull the fuse for them as I will probably never need them and don't want them accidentally turned on while boondocking.
check your 12-volt fuses. They may be on a circuit with something else. If you don't see a fuse labeled "Tank Heater", pull the switch out of the wall, put a voltmeter/light across the switch if it not lighted. You'll have to find a ground. Then go pull fuses. If something else stops working you'll know why.
