Old 02-11-2017, 11:56 AM   #1
EMS
hello, does the Wildcat Maxx have an energy management system that sheds other appliances when one is drawing to much? Thank you.
bedelstein is offline   Reply With Quote
Old 02-11-2017, 01:14 PM   #2
Left Coast
Don't think so, other then fuses and circuit breakers
Old 02-13-2017, 01:38 AM   #3
not likley
Old 02-13-2017, 07:01 AM   #4
davel1971's Avatar
I'm 99.9% sure the answer is no. I've only ever seen very high end RVs come with a power protection device of any sort. Progressive Industries EMS series is what you want.
David & Lynn
Old 02-13-2017, 07:07 AM   #5
wmtire's Avatar
If it did, it would most likely be listed in the sales brochure for it, as that would be a good selling point.
You can find these online at the Forest River website.
http://forestriverinc.com/brochures/...xxBrochure.pdf
2011 Flagstaff 831 RLBSS
I've reported my DNA missing just in case it's found somewhere bad.
Old 02-13-2017, 07:29 AM   #6
A while ago I chased this down when someone asked what their "AESS" was. Turns out that Intellitec has an automatic module https://www.amazon.com/Intellitec-00...=1&*entries*=0 that manages an issue like this. In fact, there is an electrical code requirement that you cannot install more than 5 breakers on a 30 amp panel if there are two or more thermostatically controlled loads (A/C, H/W, reefer) without one. This unit will automatically shed a load (your electric hot water heater) when something else (microwave?) cycles up and shares the same 20 amp breaker. If it has more that 5 breakers on a 30 amp panel, A/C, electric HW and residential reefer...and was made after 2012, it should have one.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 02-13-2017, 07:52 AM   #7
VinceU's Avatar
Have seen a system like this where the display/control panel was marked "power line". No control, no system!
Old 02-13-2017, 08:12 AM   #8
that is a different system from Intellitec. This one is at https://www.amazon.com/Intellitec-00...rds=intellitec
From the looks of the documentation, it is buried behind the breaker panel and has no real controls or displays. Just sheds one load in favor of the other.
2015 335DS
Old 02-13-2017, 10:19 PM   #9
Thank you all
